head/rocker assy. nuts and a compression Q, sorry about the long post |
tat2dphreak |
Jul 5 2003, 06:06 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
ok, I'm reassembling the heads onto the engine...
Haynes suggests the nuts that hold the heads be 23ft./lb... I'm starting to question my torque wrench... these things are already VERY tight on the studs and the wrench hasn't clued me in on getting close to 23... my question is this: is it possible to get these nuts too tight? will I damage the heads if I keep going until the torque wrench feels like telling me to stop? (IMG:style_emoticons/default/idea.gif) also, how tight should the rocker assy. nuts be? these didn't seem *REALLY* tight when I took them off... (IMG:style_emoticons/default/confused24.gif) next: according the all-knowing Haynes 120-156 lbs of compression is normal, 100 minimum... I'm assuming this is with the engine cool... how much compression is good when the engine is warm? should it me more? less? one last Q: how much effect can carbon buildup on the heads have on the compression?... when I removed one head(the 1,2 cyls) there was bad carbon buildup which cleaned up easily... a little B-12 and some elbow grease with a toothbrush easy... this head now looks much better than the one that I was going to put on that side... this side of the engine had good compression when the engine was cool 130/140 but only 60-75 warm... after the cleanup... would it be safe to use this head again? or should I just use the other one? |
tat2dphreak |
Jul 6 2003, 08:41 AM
I think I need a smaller torque wrench to truly torque those... my wrench is a craftsman and starts at 25...
I wasn't straining on the wrench... it just kept tightening more and more... much tighter it seems than what I removed.... one or 2 finally clued me in saying 25lbs... but the others were tight enough as is to make me nervous... my only guess is that either I'm being to cautious or I was wrenching too fast and the wrench missed it's mark... either way I plan to take that head off again today and start again. I have one more question... the other head I plan to put on has a broken exhaust stud... because of rust and the break, I cannot get 1 nut on... let alone 2 nuts to get the stud out... vise grips just slide around removing the rust... how can I get this stud off? thanks for the help guys! (IMG:style_emoticons/default/wavey.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 11:15 PM |
