What Distributor do I have here?, Problems with timing... |
Beebo Kanelle |
Sep 12 2017, 10:18 AM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
I have what is supposed to be a bone stock 2.0 with a GA case...
Setting the timing has been driving me nuts, so I pull the distributor. The numbers are as follows: 0 231 174 009 039 905 205 and I vacuum tested the diaphragm advance / retard only to find there's no advance, no retard! Is anybody familiar with this distributor? is it a bus distributor? Anybody tried the 123ignition distributor? any and all advice is greatly appreciated. |
Mblizzard |
Sep 12 2017, 11:21 AM
This might be helpful.
Should be 1973 Type 4 for 914. Bosch_Tune_Up_Parts.pdf ( 527.89k ) Number of downloads: 337 |
Mblizzard |
Sep 12 2017, 11:24 AM
I have what is supposed to be a bone stock 2.0 with a GA case... Setting the timing has been driving me nuts, so I pull the distributor. The numbers are as follows: 0 231 174 009 039 905 205 and I vacuum tested the diaphragm advance / retard only to find there's no advance, no retard! Is anybody familiar with this distributor? is it a bus distributor? Anybody tried the 123ignition distributor? any and all advice is greatly appreciated. I have the 123 running on mine with the electronic trigger points. It works very well. Will be converting to controlling ignition with the Microsquirt soon because I can. they also have a programmable version of the dizzy which I would thin would be the way to go. You can set your timing by Bluetooth. |
porschetub |
Sep 12 2017, 01:55 PM
Did you test the vacuum with the unit on or off the distributor?
DRPHIL914 |
Sep 12 2017, 04:34 PM
Dr. Phil Group: Members Posts: 5,760 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have what is supposed to be a bone stock 2.0 with a GA case... Setting the timing has been driving me nuts, so I pull the distributor. The numbers are as follows: 0 231 174 009 039 905 205 and I vacuum tested the diaphragm advance / retard only to find there's no advance, no retard! Is anybody familiar with this distributor? is it a bus distributor? Anybody tried the 123ignition distributor? any and all advice is greatly appreciated. I have the 123 running on mine with the electronic trigger points. It works very well. Will be converting to controlling ignition with the Microsquirt soon because I can. they also have a programmable version of the dizzy which I would thin would be the way to go. You can set your timing by Bluetooth. id be interested in your 123 if you think you might selll it after you fully convert to ms. let me know- phil |
turk22 |
Sep 12 2017, 07:31 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
Beebo Kanelle |
Sep 12 2017, 08:09 PM
Thanks to all.
I tested the vacuum canister both on and off the distributor. nada. big leak. It looks like I'm gonna go megasquirt. I'll take the D-jet and put it on the shelf... for if and when. |
Lo-Fi Version | Time is now: 1st May 2024 - 05:09 PM |
