WTB : Shoulder bolt, Found 2 of 'em... Thanks Joe ! |
drifter914 |
Sep 12 2017, 03:26 PM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
Looks like the enclosed pic, a little over an inch long. They secure the rear trunk lid hinges to the body. I have one, missing one. Please PM me if you have an extra. I can't get my rear trunk lid to stay aligned with a reg. bolt in one side .
Thanks... Terry About 1.5" long, 12mm socket head, 8mm x1.25 thread size... anyone ? |
KevinW |
Sep 13 2017, 05:50 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I have one you can have. PM me your address.
Kevin |
IronHillRestorations |
Sep 13 2017, 06:20 AM
There's a modification I do to those. You drill a small hole through the shoulder (like 1/32) and down the center (3/16 IIRC) for a grease fitting. Then you chuck the bolt in your drill press and machine a groove on the same line as the 1/32 hole.
This allows you to grease the pivots |
drifter914 |
Sep 13 2017, 03:45 PM
O.K. Kevin ! Thanks for helping out with the shoulder bolt. Now I'll be able to get that rear trunk lid stabilized.
KevinW |
Sep 13 2017, 04:14 PM
O.K. Kevin ! Thanks for helping out with the shoulder bolt. Now I'll be able to get that rear trunk lid stabilized. Terry This is what I have Kevin Attached thumbnail(s) |
Sep 13 2017, 04:22 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm sorry I didn't come through with one. The two on my parts car are so rounded off, the socket wouldn't loosen them. PO must have used a vice grip. (IMG:style_emoticons/default/headbang.gif)
drifter914 |
Sep 14 2017, 09:01 AM
[quot (IMG:style_emoticons/default/bye1.gif) e name='mepstein' date='Sep 13 2017, 03:22 PM' post='2527302']
I'm sorry I didn't come through with one. The two on my parts car are so rounded off, the socket wouldn't loosen them. PO must have used a vice grip. (IMG:style_emoticons/default/headbang.gif) [/quote] Hi Mark... I figured if you found a good one you would have let me know . Thanks for checking ! Terry (IMG:style_emoticons/default/bye1.gif) |
drifter914 |
Sep 14 2017, 06:10 PM
I have one you can have. PM me your address. Kevin Thanks for looking, Kevin... Still searching... (IMG:style_emoticons/default/dry.gif) |
Dominic |
Sep 14 2017, 08:28 PM
Dominic Group: Members Posts: 991 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Drifter,
All of the shoulder bolts I have seen on 914 rear trunk hinges (New and Used) are identical to the short bolt on the right in the picture above. Not sure you are going to find a match for yours. Cheers, Dominic |
drifter914 |
Sep 15 2017, 09:26 AM
Drifter, All of the shoulder bolts I have seen on 914 rear trunk hinges (New and Used) are identical to the short bolt on the right in the picture above. Not sure you are going to find a match for yours. Cheers, Dominic Thanks Dom... yes, the fog is slowly lifting... seems a PO had misplaced the original bolts when they did the restoration & I inherited the result... which is a regular 8mm bolt in one side & the bolt in my original post in the other. So, I assumed one was correct & used it for my example. They were both wrong & you are correct. I have a PM from Joe, who may have what I need. Thanks... Terry |
Lo-Fi Version | Time is now: 23rd April 2024 - 03:34 AM |
