914 Emblem Install ? |
dgraves |
Sep 13 2017, 06:48 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
I have a 1974 2.0 and there aren't any holes for a metal 914 emblem below the rear trunk. I understand the 1974 models had plastic stick on emblems? Does anyone have measurements from the trunk latch where to drill and install a metal 914 emblem?
Thank you. |
Tom_T |
Sep 13 2017, 07:00 PM
Nope, the 74s had molded plastic emblems with pins which AFAIK are still available today from Porsche etc. (some early 74s were metal) - not stick on.
The decals came with the 75-76 only. You should have 2 sets of 2 holes on your back wall of the rear trunk, 2 for "914" & 2 for "2.0" (or 1.8). If yours only has the 2 holes where the 914 emblem goes - & no evidence of a pair for 2.0 welded up - then maybe somebody used an early 70-72 back wall (& some early 73s like mine). Just drill the missing holes. Hopefully someone else can post pix of the 4 holes' locations, cuz I don't ha access to my pix now. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Coondog |
Sep 13 2017, 09:30 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Don't drill the holes, clip off the pins and cut down some 3M tape to fit.
(IMG:style_emoticons/default/dry.gif) maybe I lean this way cause of the money I spent filling the holes, and no I didn't put emblems back on. If I had to do it again, I would have filled in the trunk button hole to. |
SKL1 |
Sep 13 2017, 09:35 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
When I restored my '73 I filled in the holes and put a 914 decal (sticker) on. If you want the actual plastic 914 I too would cut off the pins and stick it on. Why drill holes in a perfectly clean body???
dgraves |
Sep 13 2017, 10:11 PM
Frankvw |
Sep 13 2017, 11:25 PM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
http://www.p914.com/p914_badges_2.0-vinyl.htm
I would not drill holes as already mentioned before. |
AZ914 |
Sep 14 2017, 12:01 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I think the 76 was the only model to have stickers. My 75 has plastic emblems with pins. When I had a new 3.2 badge made, I just used 2-sided tape, its been on there for 6 years with no problems.
bbrock |
Sep 14 2017, 08:15 AM
dgraves |
Sep 14 2017, 12:11 PM
Thank you. Are these durable? Dan |
dgraves |
SKL1 |
Sep 14 2017, 01:39 PM
I just had a local graphics shop make the sticker- I gave them dimensions and a picture. My front crest is also a sticker, just like the GT3 RS!! Gotta save weight you know... (IMG:style_emoticons/default/smile.gif)
RickS |
Sep 14 2017, 10:11 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
sb914 |
Sep 15 2017, 06:00 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Contact Mueller for a gorgeous emblem like mine with or without the -6. It is stuck on with 3M double stick tape and it is Stuck. (IMG:style_emoticons/default/agree.gif) |
cwpeden |
Sep 15 2017, 07:35 AM
bbrock |
Sep 15 2017, 09:16 AM
They aren't all at the same height. You need a measurement for each hole. Good catch. I guess I wasn't fully awake yet. I edited the original pic with all height dimensions. Thanks for catching that. |
cwpeden |
Sep 15 2017, 12:37 PM
My kid thought it would be funny to put mine upside down once. If it wasnt for the 2.0 being on a slant i wouldnt have notice for weeks
dgraves |
Sep 17 2017, 09:23 PM
Lazydog925 |
Sep 17 2017, 09:36 PM
Newbie Group: Members Posts: 4 Joined: 8-August 16 From: East Bay Member No.: 20,279 Region Association: None |
Does anyone have the measurements or the hole for the European VW/Porsche rear badge?
thank you |
horizontally-opposed |
Sep 18 2017, 07:13 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I clipped the pins to install a Euro "914-VW-Porsche" badge, and now wish I'd had the template (ideally) to drill the holes in my hole-less rear. The tape works and hold it on, but the emblem would be prettier flush against the paint.
YMMV Attached thumbnail(s) |
RickS |
Sep 18 2017, 08:27 PM
Great looking car.
Lo-Fi Version | Time is now: 23rd April 2024 - 04:47 AM |
