Sot 912E #483, Carbs? |
BK911 |
Sep 15 2017, 06:19 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Ok guys, not sure what to do.
Recent acquisition of a '76 912E #483. As most of you know, it is powered by a 914 2.0 with Ljet induction. Motor runs well, but idles high and runs warmer than expected, so I am thinking vacuum leak. Of course will go through ignition first, since 90% of FI problems are ignition. (IMG:style_emoticons/default/smile.gif) Chased FI problems on my 1.7 djet for a couple years before I gave up and put on some EMPIs. Been running awesome for years now! So.... Thinking of spending a couple of hours tuning the ljet and replacing all vac lines, but also thinking of just taking the plunge and putting on some EMPIs. Thoughts ? Don't care about resale; car is going in dd rotation and will get DRIVEN!! |
Dave_Darling |
Sep 18 2017, 04:36 PM
If you're using a timing light with an advance knob built in, check that it is set on '0'. Then you can use the stock timing marks.
Double check that what you think is TDC or the timing mark really is TDC or the timing mark. I may or may not have committed both of those errors at various points in time. If so, I'm not admitting to it! (IMG:style_emoticons/default/wink.gif) --DD |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:24 AM |
