Sot 912E #483, Carbs? |
BK911 |
Sep 15 2017, 06:19 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Ok guys, not sure what to do.
Recent acquisition of a '76 912E #483. As most of you know, it is powered by a 914 2.0 with Ljet induction. Motor runs well, but idles high and runs warmer than expected, so I am thinking vacuum leak. Of course will go through ignition first, since 90% of FI problems are ignition. (IMG:style_emoticons/default/smile.gif) Chased FI problems on my 1.7 djet for a couple years before I gave up and put on some EMPIs. Been running awesome for years now! So.... Thinking of spending a couple of hours tuning the ljet and replacing all vac lines, but also thinking of just taking the plunge and putting on some EMPIs. Thoughts ? Don't care about resale; car is going in dd rotation and will get DRIVEN!! |
GeorgeRud |
Sep 24 2017, 12:46 PM
Time to remove and rebuild the pedal box as well as replace the master cylinder. Try to keep the L-Jetronic and get the correct distributor- you'll be happier in the long run. Today's fuels don't play well with carbs unless the car is driven daily to prevent the fuel from jelling in the float bowls.
Lo-Fi Version | Time is now: 15th May 2024 - 12:27 PM |
