How did you route your CHT or AFR wiring |
Morrie |
Sep 18 2017, 11:22 AM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
I am ready to route wiring from the engine bay to the cockpit for my AFR meter. I am curious about where folks have routed wires / drilled holes, etc. I know I want to stay away from ignition components based on experience, and it looks like the current wire harness access point is pretty much stuffed. The connector is for an Innovate MTX-L and the connector to feed through to the cockpit is probably 1/2 an inch long, so it is more than fishing a couple wires.....
Appreciate any experience based advice. The exhaust bung is welded in place so this is next on the agenda so I can start working on tuning the D-Jet setup. Kind regards, |
Olympic 914 |
Sep 19 2017, 09:06 AM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I drilled a hole next to the release for the engine lid. same as your situation the connector for my AFR was too big to thread through existing wiring harness. then ran the wires behind the backpad and down the top of the tunnel under the rug.
Morrie |
Sep 19 2017, 10:53 AM
I drilled a hole next to the release for the engine lid. same as your situation the connector for my AFR was too big to thread through existing wiring harness. then ran the wires behind the backpad and down the top of the tunnel under the rug. I heard somewhere that part of the "firewall" was double layer sheetmetal and part was single. Something about the difference of above vs below the engine tin. Ideally for shortest route of wiring would be to go directly into or beside the tunnel I suppose. I was thinking of routing it there in order to get away with not having to run an extension cable for the gauge..... but that is an option.... I believe I have the 8 foot cable now.... which got me there with my 912. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:23 PM |
