AFR bung installation stock exhaust, Looking for where to install the exhaust bung on stock 2.0 |
nditiz1 |
Sep 22 2017, 08:01 AM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
That looks pretty much about where I've got mine mounted. About 3 years since installation and no apparent problems. Gauge starts reading within a few seconds of starting cold. Same here, can take a photo and post it tonight if you want. Has been working great for me also. Falcor75 - definitely post that pic. I dropped the muffler off this morning. Should pick it up this afternoon and install when I get home. |
Mark Henry |
Sep 22 2017, 08:10 AM
That's good but it might not be quite the 10 or 2 o'clock position, easily adjusted with the heating and bar trick.
falcor75 |
Sep 22 2017, 11:00 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
nditiz1 |
Sep 22 2017, 12:57 PM
Here is the finished product:
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-18763-1506125641.1.jpg) |
nditiz1 |
Sep 22 2017, 12:58 PM
Mark Henry |
Sep 22 2017, 02:38 PM
Problem with that install is it's closer to a 9 o'clock position, so the sensor may not drain all of the moisture out of the sensor. Heat the surrounding metal cherry red, then taking a bar bend the sheet metal and bung up 30 degrees and closer to the 10 O'clock position. |
falcor75 |
Sep 23 2017, 01:45 AM
Umm no, I'm not putting a torch to my Scart muffler.
The sensor is fine, its heated and has been there for 18 months with zero issues. I think the 10-12 position has more relevance if you mount the sensor in a smaller diameter exhaust pipe, in my case its still 4 inches from the bottom of the "tube" so any moisture trapped in the exhaust will have a hard time reaching the sensor tip. |
Lo-Fi Version | Time is now: 19th April 2024 - 07:41 PM |
