V8 cooling ideas., Only because I have the parts! |
BRAVE_HELIOS |
Sep 18 2017, 05:06 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
I think I have pretty much exhausted the ways to make a mechanical Chrysler/Renegade water pump setup run as efficiently as possible.
At this time; I do notice that at idle, the engine temp creeps up but as soon as I give it throttle; the temp comes down by almost 10 degrees... it stands the reason since at higher rpm's, there is more water flow. Now for the ideas... I have a spare aux electric water pump from my 545i. BMW uses the pump to assist in pumping coolant to the heater core. It is a small unit and I am sure the flow is low compared to the standard electric or mechanical water pump. Could I integrate this lil ol electric unit to flow a more consistent rate, even at idle? Would it interrupt the flow from the mechanical w/p? The other item is the oil cooler that came with the engine but I have yet to install. Would this help cool the engine down and by how much? |
DM_2000 |
Oct 24 2017, 04:53 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
I'd probably fit 2 maybe 3 fans. Find a fan the same dim as the small dim of the cooler.
There are tons of electronic surplus places, I'd hit them up first. Along with a place that scraps out computers. I've seen Dell towers have a fan that looks to be sized right, not sure of voltage though I's expect 12V Check out the traditional hand drawn product pics https://www.sciplus.com In CA https://www.allelectronics.com/ Or type in to google " electronic surplus " and " <the state you are in> " |
Lo-Fi Version | Time is now: 20th May 2024 - 05:39 AM |
