V8 cooling ideas., Only because I have the parts! |
BRAVE_HELIOS |
Sep 18 2017, 05:06 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
I think I have pretty much exhausted the ways to make a mechanical Chrysler/Renegade water pump setup run as efficiently as possible.
At this time; I do notice that at idle, the engine temp creeps up but as soon as I give it throttle; the temp comes down by almost 10 degrees... it stands the reason since at higher rpm's, there is more water flow. Now for the ideas... I have a spare aux electric water pump from my 545i. BMW uses the pump to assist in pumping coolant to the heater core. It is a small unit and I am sure the flow is low compared to the standard electric or mechanical water pump. Could I integrate this lil ol electric unit to flow a more consistent rate, even at idle? Would it interrupt the flow from the mechanical w/p? The other item is the oil cooler that came with the engine but I have yet to install. Would this help cool the engine down and by how much? |
cali914 |
Sep 20 2017, 06:20 PM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
I am using same radiator in my v6 honda 914 as i did with the v8 only difference is i am using honda stock water pump 180 degree all day long.
BRAVE_HELIOS |
Sep 21 2017, 08:36 AM
I am using same radiator in my v6 honda 914 as i did with the v8 only difference is i am using honda stock water pump 180 degree all day long. Would love to see pictures of this! You have the same dual pass rad? Does this make that much of a difference compared to a single pass, 2 row all aluminium radiator? Which is better to change first my wp to electric or my rad to a dual pass unit? |
Lo-Fi Version | Time is now: 8th May 2024 - 10:09 PM |
