V8 cooling ideas., Only because I have the parts! |
BRAVE_HELIOS |
Sep 18 2017, 05:06 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
I think I have pretty much exhausted the ways to make a mechanical Chrysler/Renegade water pump setup run as efficiently as possible.
At this time; I do notice that at idle, the engine temp creeps up but as soon as I give it throttle; the temp comes down by almost 10 degrees... it stands the reason since at higher rpm's, there is more water flow. Now for the ideas... I have a spare aux electric water pump from my 545i. BMW uses the pump to assist in pumping coolant to the heater core. It is a small unit and I am sure the flow is low compared to the standard electric or mechanical water pump. Could I integrate this lil ol electric unit to flow a more consistent rate, even at idle? Would it interrupt the flow from the mechanical w/p? The other item is the oil cooler that came with the engine but I have yet to install. Would this help cool the engine down and by how much? |
DM_2000 |
Oct 19 2017, 05:06 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
I'd put some muffin fans under the cooler blowing upwards. Maybe wire them into the rad fan circuit.
These fans are those square fans found on computers and other stuff. |
BRAVE_HELIOS |
Oct 24 2017, 11:19 AM
I'd put some muffin fans under the cooler blowing upwards. Maybe wire them into the rad fan circuit. These fans are those square fans found on computers and other stuff. Checked out DigiKey's website: https://www.digikey.com/products/en/fans-th...amp;pageSize=25 What do you suppose a good CFM rating would be for a couple of muffin fans mounted to my oil cooler? |
Lo-Fi Version | Time is now: 9th May 2024 - 10:43 AM |
