Inverted 915 Project, No Description needed |
pcar916 |
Sep 18 2017, 06:06 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Hi Folks,
I'm returned after a brief hiatus with a question. Some of you remember I have Penelope, a 914/993 machine. I have decided to replace the 914 transaxle with an inverted 915. How many of you have done it and do you have stories? :-) My thinking is as follows... 1. Billet side plate. I've already paid the price several times for deflection. The 993 is not a huge hp machine, maybe 270hp with a bit less torque depending on the RPM/throttle. 2. Cable shifter (any suggestions that don't include making one myself.) It would be fun but might take longer than I want to wait. 3. Already have the turbo flanges/CV's to accommodate the deflection angle. 4. Oil cooler already installed whether I need it or not. Already addressed in the trans cooler thread from years ago. Thought seriously about building a side shifter 915 with Bott's kit, but as good as it is, and it is. I don't want to take the gear-stack out every time I want to check the LSD plates/R&P. I've gotten a replacement 993 engine while I jazz up her (tired) original engine, but since I haven't done one of these builds, I figured I'd ask this crowd about it because I'd rather drive her while I build the engine. Glad to be back! Ron |
pcar916 |
Oct 23 2017, 10:49 AM
Thanks Gents,
ConeDogger: "McMark has the design for a cable shifted 915 in his head and computer" I'll follow up and see if his shifter is aftermarket or not. Also, I wish I could move the Guard LSD from the 914 to the 915 box... the bearing surfaces aren't the same size though. Jeff: Wevo's a nice solution. But it's for a non-inverted 915. Inversion puts the shift rod on the top where a standard rod system doesn't reach without universal joints, cams and levers. Non-inverted leaves me with a flipped R&P and more complicated diff maintenance. Cracker: That shifting is wonderful! Since I can't start working on my 914 until I get finished with current projects I have time to noodle over this a bit. If I can figure out how to do the G86/20 box I'll sell off the 915's and a few of the 914 boxes... clear out some space! Lookin' forward to ceasing the engineering work and building it instead! Thanks again guys. Ron |
Lo-Fi Version | Time is now: 18th May 2024 - 06:28 PM |
