Lead Paint, Body work at home? |
AndyB |
Sep 21 2017, 10:00 AM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
Lead based paint can be found in homes/buildings if they were painted up into about the late 1970s, figure on about 1980 when the warehoused material was used up. I have not heard that automotive paints had lead in them, cite your source for that information please. All paints had lead in them, 1950's -60's levels saw reductions, by 1978 lead was removed from house and consumer paints, but it was still present in most industrial paints, including auto paint, right up to the late 80's. Yellow thru orange had the highest levels. Where are your references/citing materials? So far it's all speculation without data, backing it up. |
MBowman325 |
Sep 21 2017, 09:15 PM
Member Group: Members Posts: 465 Joined: 14-July 05 From: Oklahoma City, OK Member No.: 4,413 Region Association: Southwest Region |
Lead based paint can be found in homes/buildings if they were painted up into about the late 1970s, figure on about 1980 when the warehoused material was used up. I have not heard that automotive paints had lead in them, cite your source for that information please. All paints had lead in them, 1950's -60's levels saw reductions, by 1978 lead was removed from house and consumer paints, but it was still present in most industrial paints, including auto paint, right up to the late 80's. Yellow thru orange had the highest levels. Where are your references/citing materials? So far it's all speculation without data, backing it up. Based off other documentation I found and referenced above I searched and found the following: http://us.ppgrefinish.com/PPG-Refinish/Pro.../Deltron#expand http://us.ppgrefinish.com/PPG-Refinish/Not...oduct(s)-DMA322 So according to this DMA322 was discontinued last year. Both the above and first link indicate that it contains lead. (Discontinued and used are indeed two different topics, but that indicates that auto paint up until last year appears to have been available containing lead. This is surprising to me) https://buyat.ppg.com/rep_pafpainttools_fil...s/tdb/6-204.pdf Note that the above doesn't reference that it has lead but does have a note that if you sand lead based paint you'll be exposed to dust that contains lead. (paraphrased) Again, I've done some empirical testing and panels on my 914s test positive for lead so I wouldn't say it's baseless. (I've also readily pointed out that the swab test can return bad results.) |
Rand |
Sep 21 2017, 09:30 PM
This may do something epic...
Yellow is high in lead. Yellow used to be fast. Myth busted. Now we know it's heavier and slower. Like lead. Black is faster. (IMG:style_emoticons/default/tongue.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 09:26 AM |
