turning tail shifter into a sidewinder: sources for bushings?, Have I been mislead? |
Calwaterbear |
Sep 19 2017, 08:59 PM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
Ok guys, have a 72, with the tailshifter. so I salvaged everything from a junked 74 - from the shifter to the transmission.
so first - i have been told that you just need to change the linkages, but in reading on the Pelican, they indicate you would need the newer transmission as well - IE no conversion, it is a replacement - trans and shifter. Can anyone confirm that? my hope/plan is to leave the current trans in the 72, and turn it into a sidewinder. so took all the shift rods etc, wire wheeled em, hit em with primer and an enamel for longevity and rust protection. So I guess next step is to replace all the bushings, Right? so anyone have a favorite supplier? does 914 rubber carry em? I assume pelican does. I'm hoping they come as a kit! somebodty needs to lie to me and tell me this is a simple straightforward conversion, slap it back in, 2 hours tops! |
rhodyguy |
Sep 21 2017, 07:15 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The aluminum base plate pictured is only used with a short shift kit. The front boot for the rear shift rod does not work on a tail shift chassis. As I mentioned in the link provided in post #3, you need to inspect the shift lever assembly or you'll wind up with problems right from the start.
ChrisFoley |
Sep 21 2017, 08:36 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... The front boot for the rear shift rod does not work on a tail shift chassis. ... My firewall bearing has a groove on the housing to support the sideshift boot, and fits either early or late firewall. (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 04:12 PM |
