turning tail shifter into a sidewinder: sources for bushings?, Have I been mislead? |
Calwaterbear |
Sep 19 2017, 08:59 PM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
Ok guys, have a 72, with the tailshifter. so I salvaged everything from a junked 74 - from the shifter to the transmission.
so first - i have been told that you just need to change the linkages, but in reading on the Pelican, they indicate you would need the newer transmission as well - IE no conversion, it is a replacement - trans and shifter. Can anyone confirm that? my hope/plan is to leave the current trans in the 72, and turn it into a sidewinder. so took all the shift rods etc, wire wheeled em, hit em with primer and an enamel for longevity and rust protection. So I guess next step is to replace all the bushings, Right? so anyone have a favorite supplier? does 914 rubber carry em? I assume pelican does. I'm hoping they come as a kit! somebodty needs to lie to me and tell me this is a simple straightforward conversion, slap it back in, 2 hours tops! |
Calwaterbear |
Sep 21 2017, 09:13 AM
Ok Thanks for all the information guys, it really helps. so I will change up my plans. For right now, I will go ahead and recondition the tail shifter, in an attempt to get this thing on the road ASAP, in the meantime, I will collect the 2 or 3 side shifter conversion parts i still need, and find someone to go through and freshen up the sideshifter trans, so first time I pull the engine, I'll go ahead and make the shift!
Lo-Fi Version | Time is now: 19th May 2024 - 06:43 PM |
