Clutch pedal return spring, Should pedal stay up? |
DaveO90s4 |
Sep 20 2017, 02:57 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Hi all,
With my clutch cable disconnected from the transmission my clutch pedal falls to the floor. That in turn means the only way (at present) to keep it up is to attach the cable at the transmission and adjust the turn nut. But this would mean, I think, that the clutch throw out bearing would be permanently engaged. So I think I have a problem with the return spring under the pedal assembly. I can see it is not broken, maybe just needs more tension (another turn) to do its job. Not much room to get in and do things down near the pedals and front of tunnel. What do you reckon? Thanks Dave Oz |
DaveO90s4 |
Sep 21 2017, 04:27 AM
Thanks Gents,
One less thing for me to have to fix then. Great. In my 356 having the thrust bearing permanently engaged is a big no no. Oh well, this arrangement clearly works. Best regards Dave O Oz |
Lo-Fi Version | Time is now: 10th May 2024 - 12:56 PM |
