Lower valve exhaust valve covers ?, what have I bought. |
porschetub |
Sep 20 2017, 08:39 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Picked up a pair of these part number 930 105 116 OR one is machined down which to me looks to be down around 5.5mm .
Looks like its the RH side cover with machining @ the rear. This could be simple but have a mental blank on this @ the moment. Seller told me they were of a latter motor and casting dates prove that but why was this cover milled down or is that earlier 911 fitment?,help please TIA. |
Blue6 |
Sep 20 2017, 08:45 PM
Senior Member Group: Members Posts: 1,034 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
If the 930's are used on a 914/6, they need to be milled to remove them while in the car. Can't remember which side needs to be milled. I think drivers side rear, but not positive, and not near my car to check.
Cairo94507 |
Sep 20 2017, 08:49 PM
Michael Group: Members Posts: 9,723 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Turbo lower valve covers and the driver's side is one milled when used on a 6 in a 914 chassis to be able to get it on/off with motor in the car.
porschetub |
Sep 20 2017, 10:35 PM
Think mine might be ass about face due to early 911 fitment just don't know???.
On a 914/6 the cylinder max offset is towards the rear on the RH side (cylinders 4+5 ) so maybe they are ok. If the part numbers are @ the top that should be the correct fitment....seems that way (IMG:style_emoticons/default/confused24.gif) . |
Mark Henry |
Sep 21 2017, 06:55 AM
I milled all of my fins down to the top of the fastener bosses, turbo covers are overkill.
Blue6 |
Sep 21 2017, 10:28 AM
They probably are overkill, but they look bad a$$, and seal even better. It looks like someone did the milling for your 6 application for you.
porschetub |
Sep 21 2017, 03:23 PM
They probably are overkill, but they look bad a$$, and seal even better. It looks like someone did the milling for your 6 application for you. Yes I have now worked that out.....takes me a while some days (IMG:style_emoticons/default/biggrin.gif) , thanks Blue6,funny never really looked closely @ them till yesterday,seems a little odd as the seller only sells 911 stuff,oh well one less job to do (IMG:style_emoticons/default/beer.gif) . |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:12 PM |
