Heater cable, To short! |
80cap |
Oct 6 2017, 02:16 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
I purchased a heater cable from Stoddard's a while back and it is to short. The car is a 76 but has early heat exchangers and parts. What is the correct part? I s there two different lengths?
(IMG:style_emoticons/default/confused24.gif) |
rhodyguy |
Oct 6 2017, 02:52 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,054 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Just one side or both?
JawjaPorsche |
Oct 7 2017, 02:58 AM
A lot of heater cables are bent wrong. If you still have your old cable, measure to determine correct length. Then straighten your new cable then rebend at correct spot.
Passenger side is longer. |
80cap |
Oct 7 2017, 04:17 AM
The cable won't reach either flapper control. It's just to short. There must be two sizes.
Oct 7 2017, 04:32 AM
914-6 GT in waiting Group: Members Posts: 19,220 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There are two sizes. 914rubber makes both.
914dave |
Oct 7 2017, 04:43 AM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Porschef |
Oct 7 2017, 04:57 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Those are very nice. I had replaced my cables when I backdated the exhaust, never thought to measure new vs old. Either way, there's some adjustability with the flapper's clamps, and making sure that they're just fully closed when the heat lever is pushed all the way down is critical to both ensuring no heat enters the cabin when unwanted, and fully open on them chilly days...
Oct 7 2017, 05:46 AM
Two sizes? Learned something new. Mine came up short with the aftermarket six heat exchangers and I thought they were wrong. Went thru the process of making extensions. Guess I'll have to give Mark a call. Making cool stuff while some of us can barely assemble cool stuff is sort of unfair. (IMG:style_emoticons/default/biggrin.gif) |
TX914 |
Oct 7 2017, 06:04 AM
Alan-B Group: Members Posts: 167 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
The cable won't reach either flapper control. It's just to short. There must be two sizes. Note the actuating levers on the control boxes face upwards. Otherwise at least one side of the cable will be too short if not both. I have a 76 with backdated exhaust and I'm pretty sure I have the 70-74 cable which fits correctly. |
914Sixer |
Oct 7 2017, 07:10 AM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
There is 3 DIFFERENT cables. One for the -6, one for all the 70-74 engines and a third set for the 75-76.
Oct 7 2017, 07:13 AM
There is 3 DIFFERENT cables. One for the -6, one for all the 70-74 engines and a third set for the 75-76. I don’t know if Mikey made the 6 version. I hope so. Edit - he has it listed but not in stock. I need a couple. Attached thumbnail(s) |
Matty900 |
Oct 7 2017, 08:29 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
There is 3 DIFFERENT cables. One for the -6, one for all the 70-74 engines and a third set for the 75-76. I don’t know if Mikey made the 6 version. I hope so. Edit - he has it listed but not in stock. I need a couple. We make them so, don't worry about the inventory count on website. We also make the "nipples that go on the end of the tubes comming out of the firewall too. Along with related items http://shop.914rubber.com/searchquick-subm...keywords=Heater (IMG:style_emoticons/default/beerchug.gif) |
914dave |
Oct 8 2017, 05:29 AM
Two sizes? Learned something new. Mine came up short with the aftermarket six heat exchangers and I thought they were wrong. Went thru the process of making extensions. Guess I'll have to give Mark a call. Making cool stuff while some of us can barely assemble cool stuff is sort of unfair. (IMG:style_emoticons/default/biggrin.gif) It's the only small advantage I have in this world. So I'll try not to feel guilty about it. Hehe |
Mikey914 |
Oct 8 2017, 02:54 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
A benefit of actually being a manufacturer is if yon need a custom length it's easily done. Also when you see stuff is out of stock, it often means we haven't updated the inventory and we can easily confirm with a call.
We don't charge extra for custom lengths, but will need you to call out how long you want the cables. |
Oct 8 2017, 04:38 PM
A benefit of actually being a manufacturer is if yon need a custom length it's easily done. Also when you see stuff is out of stock, it often means we haven't updated the inventory and we can easily confirm with a call. We don't charge extra for custom lengths, but will need you to call out how long you want the cables. (IMG:style_emoticons/default/smilie_pokal.gif) |
Larmo63 |
Oct 8 2017, 05:00 PM
Wait, 914s have heaters???
rstover |
Oct 8 2017, 07:23 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
I had same problem. The flapper boxes were on backward. Turned them around and the cable was perfect for 74
Rob-O |
Nov 11 2019, 06:23 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Reviving an old thread.
I finally got around to installing my heater parts this weekend. Everything went in as planned but the cable is too short to reach the heater boxes. I installed the heater cable a few years back (914Rubber part). I remember having to trim some of the ends off each cable because they were so long that they couldn't navigate the curve in the cable tubes. If I remember correctly I trimmed about 1/2" off each end. When I ordered the cable from 914Rubber.com it was for a '70-74' cable length. But I have no idea what the length difference is supposed to be, so I have no idea if what I received was correct or not. My rough guesstimate is that BOTH ends of my cables are about 2" inches from properly reaching the heater boxes. My question is, for the 4 cylinder cars, which years comprised the 'short' cables and which years comprised the 'long' cables. Does anybody have measurement in inches of how long the two 4 cylinder cables should be? |
Mikey914 |
Nov 11 2019, 06:44 PM
We do have the 6 ones just not on the "New" site
https://shop.914rubber.com/PCG42407501-914-...m?categoryId=-1 |
Rob-O |
Nov 12 2019, 07:26 AM
I need the cable for a 4 cylinder.
Which cable is longer? The ‘70-‘74 cable or the ‘75-‘76 cable? I ordered a ‘70-‘74 cable but it is about two inches away from the heater box. |
Lo-Fi Version | Time is now: 19th April 2024 - 06:46 AM |
