I Need Help!, Exterminating FI Gremlins |
sportlicherFahrer |
May 22 2005, 04:55 PM
Nothing to see here. Group: Members Posts: 1,074 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
My 1.8L FI is still acting hella wierd. It likes to buck quite a bit somtimes, and then just stop bucking and run beautifully. I have no clue what it is, but I have had all the relays and what not in the engine compartment out and cleaned. Sounds like I have a vac leak, but I cant find it. I have new plugs, cap and rotor, wires, and she has crane ign. on the motor as well. I am about to pull the fuse panel out and clean all the crap off of it. Any other suggestions? I am lost.
Also, if anyone from the surrounding area wants to stop by and have a look themselves, give me a call at 253-848-8320. |
May 22 2005, 07:39 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
if i recall right, the 1.8L L-Jet required a tight seal on the oil-filler cap (yes, the cap!) to run right. you might want to check that! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
sportlicherFahrer |
May 22 2005, 11:19 PM
the oil cap is nice and tight, and the upper seal is in good condition. However, the lower seal doesnt look so good. It is there, but it has cracks in it.
May 22 2005, 11:31 PM
if it's the square one, made out of the corky stuff, i have a brand new one you can have ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
sportlicherFahrer |
May 23 2005, 12:11 AM
I think it is. The one that goes on the bottom of the cap? Much appreciated!
rhodyguy |
May 23 2005, 08:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,070 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
jim, i think andy is refering to the cork seal on the bottom of the oil fill tower. where the assembly meets the engine case. i have 2 new spares in my garage as well. ovals has them too. but they don't service 914s, type 4 busses? sure!!! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) check the seal where the funnel connects to the square piece and make sure the 2 nuts on the funnel are tight.
k |
sportlicherFahrer |
May 23 2005, 04:33 PM
I will check that Kevin, thanks! Will post back later, shes running good now. Maybe she was sick of the bad weather? Oval's can (IMG:http://www.914world.com/bbs2/html/emoticons/pissoff.gif) when it comes to my car.
sportlicherFahrer |
Jun 2 2005, 07:37 PM
Ok. heres the update.
I have a basically stock 1.8L FI. It has a Crane Fireball ign. box on it, and thats the only engine modification as far as electrical is concerned. Just replaced the plugs and CHT sensor, recently replaced the cap and rotor. wires look good. ground connections look good. dont think there are any vac leaks. So here is the problem. My car idles at about 2200-2400 rpm and cuts in and out at about 4500 rpm. tach needle bounces around when it cuts out and when decelerating. also sounds like there is a VERY small backfire out the exhaust. Those are all the symptoms i can think of right now. I am totally lost to what could be causing these problems, so any help would be much appreciated. Thank you! |
Jun 2 2005, 08:19 PM
stupid question: what is a "spirited Treiber" ??? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
ThinAir |
Jun 2 2005, 10:44 PM
Best friends Group: Members Posts: 2,532 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Those symptoms sound like it could be the throttle positoning switch. At least on a D-Jet those are what Brad Anders describes as symptoms associated with a bad tps. I don't know if the L-Jet FI uses the same style tps. On a D-Jet you diagnose this by unplugging the tps and if the problem goes away then you know you need to replace it.
TROJANMAN |
Jun 2 2005, 10:52 PM
Looks nice in pictures......... Group: Members Posts: 5,249 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
does it happen mostly when cruising between 3rd and 4th?
sportlicherFahrer |
Jun 2 2005, 11:06 PM
Andy, spirited doesn't translate in German, but Treiber means driver.
I dont think the L-jet uses a tps like the D-jet. It does have a throttle valve switch though. And this problem happens in any gear and is starting to sometimes happen around 3500 rpm. |
Jun 2 2005, 11:19 PM
i hate to burst your bubble, but Treiber does not mean Driver in the sense of driving a automobile ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Driver = Fahrer spirited in this context could be translated into fast or sporty which means the right translations would be: schneller Fahrer = fast Driver = spirited Driver sportlicher Fahrer = sporty Driver = spirited Driver "Treiber" is someone who herds animals or a "beater" in hunting jargon (the guys that crawl through the brush to flush out animals) ... (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Andy |
sportlicherFahrer |
Jun 3 2005, 07:47 AM
thank you Andy. I only took 1.5 years of German in HS, so I am a little rusty on those translations. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
sportlicherFahrer Perhaps a name change wiould save some people a little confusion?? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) How do I do that anyways. |
ThinAir |
Jun 3 2005, 09:52 AM
You just ask an Admin - it's easy - I used to be ErnieDV. |
lapuwali |
Jun 3 2005, 10:48 AM
The high idle is very likely an air leak. You have to really look for this. Try plugging the hose between the AAR and the manifold while the engine is hot and see if that drops the idle. If so, your AAR is stuck open. Ignition timing that's too far advanced will also cause a high idle. It's possible one or both of the advance springs in the distributor have broken or come off, which allows the engine to go to full advance way too quickly, and often advances way too much. This can cause all kinds of odd running behavior. |
sportlicherFahrer |
Jun 3 2005, 06:51 PM
i am not sure if the test with the AAR hose would work, because it runs like this at ANY temp. Also, today it was idling high still, but ran great for a couple minutes and then went back to the cut out problem. Have decided to try going back to points and condensor with a blue coil to see if the Crane is messed up. and that brings up more questions.
How exactly should I time it. little difficult for me cause my pulley has surface rust or corrosion on it. Do I time it at idle with vac line off, or at full advance, or 3500 with no vac? any one else that wants to chime in with ideas is welcome to. |
markb |
Jun 3 2005, 07:08 PM
IIRC, the AAR starts open, and closes when warmed up. If it's stuck open when hot, it'll cause a high idle. |
sportlicherFahrer |
Jun 3 2005, 07:25 PM
AAR is good, already tested that. 30 ohms resistance and it closes
sportlicherFahrer |
Jun 4 2005, 11:58 AM
I took your advice Kevin and put in stock points and condensor and a blue coil. She purrs like a kitten now! Idle is great, the needle doesnt bounce, and it doesnt cut out any more. Something inside that ign. box has messed up, or inside the dizzy. Oh well. Now all I need to do is fine tune the dwell and timing. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
That was a lot cheaper than a set of carbs that wouldnt have fixed the problem anyways! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 08:24 PM |
