Turn Signal Switch, Replace? |
mmascari |
Oct 9 2017, 06:12 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
How easy is it to replace the turn signal switch? When I turn the indicator up or down it has to be in a certain position for the turn signal to activate. If I turn it all the way up or down and leave it in that position it does not activate the turn signals. I tried cleaning the contacts with no luck. Any advice other than replacement?
Attached thumbnail(s) |
Spoke |
Oct 9 2017, 07:16 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
There's not much to the turnsignal contacts. What resistance do you measure when moving the stalk to either turnsignal?
Clean the contact with very fine sandpaper, clean with contact cleaner. Make sure the contacts touch when engaged. You may need to gently bend the contacts to make better contact. I wouldn't replace it without understanding what is not working and whether the contacts can be cleaned and adjusted. |
porschetub |
Oct 9 2017, 08:27 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
There's not much to the turnsignal contacts. What resistance do you measure when moving the stalk to either turnsignal? Clean the contact with very fine sandpaper, clean with contact cleaner. Make sure the contacts touch when engaged. You may need to gently bend the contacts to make better contact. I wouldn't replace it without understanding what is not working and whether the contacts can be cleaned and adjusted. (IMG:style_emoticons/default/agree.gif) got mine working fine doing the same things,stock is best with a tidy up ,replacements can be a mixed bag...from rubbish to average. |
Lo-Fi Version | Time is now: 24th April 2024 - 02:36 PM |
