Turn Signal Switch, Replace? |
mmascari |
Oct 9 2017, 06:12 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
How easy is it to replace the turn signal switch? When I turn the indicator up or down it has to be in a certain position for the turn signal to activate. If I turn it all the way up or down and leave it in that position it does not activate the turn signals. I tried cleaning the contacts with no luck. Any advice other than replacement?
Attached thumbnail(s) |
dgraves |
Oct 11 2017, 06:02 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
What about a signal switch that does not cancel (turn off) after the turn is completed? What could be wrong?
Thank you. |
tmc914 |
Oct 11 2017, 06:30 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
What about a signal switch that does not cancel (turn off) after the turn is completed? What could be wrong? Thank you. Drives me crazy when the turn signal does not cancel. I am thinking about replacing the whole switching unit for my 1973 914. All I need is an expert to say that is most likely the thing to do and I will order up a new one this week. The High beam wont stay on either so it must be the switching unit. Get two birds with one stone. |
Lo-Fi Version | Time is now: 28th March 2024 - 06:19 PM |
