Group buy air deflector for cooling. Change airflow under the car, $28 A set. |
Mikey914 |
Oct 9 2017, 07:32 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As mentioned we've been working on these for some time. Just getting to finishing these up.
They change the airflow to help cool the engine better. $28 A set who's in? |
cary |
Dec 8 2017, 10:58 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Here's your starting point. Based on the 3 cars I looked at here at MiddleMotors the first bolt is 15mm from the jack point plate. But beware ................
Most cars have seen some sort of rust repairs so use the 15mm as a starting point. But make sure you can drill the holes and get your 8mm socket or nut driver on the other two 5mm bolts. Here's the pilots modification the bottom edge. I think Phil Knight has something like that on his G650. I put them back on Doug's car for photos but forgot a couple shots. (IMG:style_emoticons/default/mad.gif) Tomorrow |
Lo-Fi Version | Time is now: 25th April 2024 - 02:10 PM |
