Group buy air deflector for cooling. Change airflow under the car, $28 A set. |
dlee6204 |
Oct 11 2017, 02:09 AM
In for a set
914Next |
Oct 11 2017, 02:45 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Here's a pic of mine when I took them off to clean the undercoating off....before and after.
nditiz1 |
Oct 11 2017, 06:02 AM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I don't think mine are in bad shape, but I'm in to try better ones.
Mikey914 |
Oct 11 2017, 06:11 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yeah what do these things do? 4 or 6 cylinder? They weren't on the 6 as it was before their time. So from a concurs standpoint no. They will "work" on all. The idea is that the air is flowing past the opening where the engine compartment is and has been directed parallel for at least the 5-6' prior. So these are mounted at he firewall to create a low pressure area on the engine side. The hot air is sucked down and airflow is disrupted. The "vortex generators"are technically a wing-let that allows for more low pressure to build (a more efficient "wing"), and works at a lower airspeed. Honestly, the improvement I have made may only make the part 2-3% more effective (as it does in aircraft). So mine will not be 20% cooler than stock but there is data so show it is an improvement (at least on the aircraft side). Also we can easily shave these off for the CW should you you be in that crowd (and yes I do lean that way, but not a card carrying member). Hope this helps with the concept and thanks for posting the pics up!. |
hndyhrr |
Oct 11 2017, 06:19 AM
Senior Member Group: Members Posts: 554 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
I would like a set,please
JOEPROPER |
Oct 11 2017, 06:28 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I'm in for a set please.
bbrock |
Oct 11 2017, 08:02 AM
Yeah what do these things do? 4 or 6 cylinder? They weren't on the 6 as it was before their time. So from a concurs standpoint no. They will "work" on all. The idea is that the air is flowing past the opening where the engine compartment is and has been directed parallel for at least the 5-6' prior. So these are mounted at he firewall to create a low pressure area on the engine side. The hot air is sucked down and airflow is disrupted. The "vortex generators"are technically a wing-let that allows for more low pressure to build (a more efficient "wing"), and works at a lower airspeed. Honestly, the improvement I have made may only make the part 2-3% more effective (as it does in aircraft). So mine will not be 20% cooler than stock but there is data so show it is an improvement (at least on the aircraft side). Also we can easily shave these off for the CW should you you be in that crowd (and yes I do lean that way, but not a card carrying member). Hope this helps with the concept and thanks for posting the pics up!. The amazing thing about this forum is that the answers come before I even have to ask the question. Thanks Mark! Definitely in for a set. |
NeunEinVier |
Oct 11 2017, 11:20 AM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
And mine will be better NOT a URO part Lol, too funny. Don't believe Uro manufactures these anyhow. Interested, adding it to my lengthy "would be nice to have" list. EDIT: I stand corrected, apparently they do. http://www.914world.com/bbs2/index.php?showtopic=317435 |
whitetwinturbo |
Oct 11 2017, 10:12 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Yup (IMG:style_emoticons/default/confused24.gif) I'll take a set (IMG:style_emoticons/default/beer.gif)
rick 918-S |
Oct 11 2017, 10:49 PM
Hey nice rack! -Celette Group: Members Posts: 20,423 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
In for a set.
11tenths |
Oct 12 2017, 08:20 AM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
I'll take a pair of "Wingtip vortex generators", size 11 D, in brown, please.
(IMG:style_emoticons/default/sunglasses.gif) - HB |
IronHillRestorations |
Oct 12 2017, 09:16 AM
I'll take two sets
CMONNETT |
Oct 12 2017, 03:44 PM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
I'll take two sets.
Thanks, |
Mueller |
Oct 12 2017, 04:08 PM
Do these work better than the stock ones? The stock one work ok, we have been playing with adding some small "wingtip" vortex generators. On the edges, it's a part that could be cut off for the concourse crowd, but would help improve the movement of air. I generally like to spring options right before the parts are ready, but yes there will be an improvement for those that want it. (IMG:style_emoticons/default/biggrin.gif) How many volts? (IMG:style_emoticons/default/smile.gif) Put me down for a set of "improved" upon design if make one. |
rmdinmd |
Oct 12 2017, 08:29 PM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
in for a set
johnhora |
Oct 12 2017, 08:42 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Oh I'm in for one set of those "wingtip" vortex generators also...
jim_hoyland |
Oct 12 2017, 08:45 PM
Get that VIN ? Group: Members Posts: 9,263 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I’m in too
jim_hoyland |
Oct 12 2017, 08:46 PM
I’m in too
pete000 |
Oct 12 2017, 09:51 PM
Whe can we see these wing dings?
bbrock |
Oct 29 2017, 10:04 AM
Just checking where this group buy stands. Three are a few other GB items I'm getting ready to order and wondering if this can be bundled in to save on shipping.
Lo-Fi Version | Time is now: 26th April 2024 - 10:15 PM |
