Group buy air deflector for cooling. Change airflow under the car, $28 A set. |
Mikey914 |
Oct 29 2017, 10:35 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These will be in the next wave. I currently have 6 GBs open including the master cylinder, and I found my site can only take 5 codes at a time. I have a few other new items and will be grouping my GBs to save all money. The only catch is that when this group is closed, it's closed. I can't carry them over indefinitely, otherwise why do a GB?
914-300Hemi |
Oct 29 2017, 10:54 AM
Senior Member Group: Members Posts: 1,355 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
I’m in for a set.
Mikey914 |
Oct 29 2017, 10:58 AM
bbrock |
Oct 29 2017, 11:59 AM
These will be in the next wave. I currently have 6 GBs open including the master cylinder, and I found my site can only take 5 codes at a time. I have a few other new items and will be grouping my GBs to save all money. The only catch is that when this group is closed, it's closed. I can't carry them over indefinitely, otherwise why do a GB? No problem. Just wanted to double check before placing my order for master cylinder and drop link bushings. Will get them ordered today. |
JimN73 |
Nov 3 2017, 11:19 AM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
Mark, are these still open for Group Buy? One set please.
JawjaPorsche |
Nov 3 2017, 11:57 AM
I would like a pair if still open.
Noonan |
Nov 3 2017, 12:03 PM
Newbie Group: Members Posts: 5 Joined: 8-October 16 From: Colorado Member No.: 20,478 Region Association: Rocky Mountains |
I'd like set too.
cary |
Dec 7 2017, 11:11 PM
Mark stopped by for a test fit on the new air deflectors. They fit perfectly and look great.
mxkinn01 |
Dec 8 2017, 12:29 AM
Member Group: Members Posts: 217 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region |
I too have one deflector that is broken and half gone. I'm in for a set as well.
914Rubber is the best. |
bdstone914 |
Dec 8 2017, 07:42 AM
bdstone914 Group: Members Posts: 4,506 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If a car was an early 70-72 than there are no holes in the body to install them. Some measurements or a template for installation would be very helpful.
Garland |
Dec 8 2017, 07:44 AM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
I’m still in for a set.
cary |
Dec 8 2017, 07:52 AM
I can do that. I just drilled them in Doug's car.
Mikey914 |
Dec 8 2017, 10:51 AM
If a car was an early 70-72 than there are no holes in the body to install them. Some measurements or a template for installation would be very helpful. For a template you really only need to know where the 1st hole is for the side. The rest you can use the part to mark the holes. I'm very happy with the fit on these the tool is a little rough so we need to do some more polishing. Will probably take about a week as it's tool steel, and we can start some production (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/aktion035.gif) Rough test fit pics Attached thumbnail(s) |
GregAmy |
Dec 8 2017, 11:28 AM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I need a box on the shelf out there. Just keep putting parts in the box until it fills up, tape over the top and ship.
If these get done about the same time as the suspension bushings are ready to ship, may as well add two pair to the bill. |
bbrock |
Dec 8 2017, 11:39 AM
And we FINALLY get to see what a vortex generator looks like. (IMG:style_emoticons/default/aktion035.gif)
walterolin |
Dec 8 2017, 11:55 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
One set.
Thanks - again. |
74K914 |
Dec 8 2017, 04:56 PM
Newbie Group: Members Posts: 6 Joined: 5-April 17 From: Orange County , CA Member No.: 20,999 Region Association: Southern California |
One set.
Thanks |
cary |
Dec 8 2017, 10:58 PM
Here's your starting point. Based on the 3 cars I looked at here at MiddleMotors the first bolt is 15mm from the jack point plate. But beware ................
Most cars have seen some sort of rust repairs so use the 15mm as a starting point. But make sure you can drill the holes and get your 8mm socket or nut driver on the other two 5mm bolts. Here's the pilots modification the bottom edge. I think Phil Knight has something like that on his G650. I put them back on Doug's car for photos but forgot a couple shots. (IMG:style_emoticons/default/mad.gif) Tomorrow |
Mikey914 |
Dec 8 2017, 11:37 PM
Good news is I will be able to better the offer a bit too. More to come
914six |
Dec 9 2017, 10:30 AM
Newbie Group: Members Posts: 28 Joined: 29-March 10 From: Los Angeles, CA Member No.: 11,521 Region Association: Southern California |
Hi Mark,
would like a set also.. Thanks, Harry |
Lo-Fi Version | Time is now: 17th April 2024 - 08:48 PM |
