May have found my transmission problem? |
914bub |
Oct 11 2017, 12:01 AM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
I have had a shifting problem since I got my 914 almost 4 years ago. When I got the car the clutch was toast so I replaced all the clutch related parts, including the flywheel. Once I got the car driving I realized it wouldn't go into first gear. I speculated that first gear had gone out and the previous owner had driven starting out in second, finishing off the clutch. The car had been parked since 1990 and the PO is deceased so it was just a guess.
The ball bushing at the base of the shifter was destroyed so I ordered a shifter bushing kit and replaced that bushing as well as,(if I remember correctly) the two ball bushings at the firewall.The car would grind and grind but wouldn't go into first gear. After reading a bunch of threads here I decided to pull the nose cone and replaced first gear and syncho with a marginally better set of parts out of a side-shifted core trans I have here. Success! So I thought........ First gear worked well for about a week and a half, then back to the same old game. I found it hard to believe I installed parts that literally had a couple weeks of life left in them. I pulled the pedal assembly out about a year ago and then got busy playing with motorcycles. I finally got it back together and in this week.( I rebuilt it not because I thought it would solve my first gear problem but it just needed it).After getting everything together I was looking at the linkage trying to see anything awry and I found this: I apologize for the washed out picture but you should be able to see what I'm talking about. The bushing the shift rod goes through has NO play although it is old. The shift rod slides freely through it as well. I loosened the bracket and pryed it so the shift rod was more centered in the linkage coming out of the transmission but it seems like it could go a little higher up and be a little "happier". Sorry I didn't take an after picture, I can tomorrow. My biggest question is should the end of the shift rod be as "hourglass" shaped as it is or is that all attributable to wear? I can drop the shift rod for a better picture, or if someone has a picture of a "good" one I can compare to? If it is worn our machinist at work can build it up if needed so I can shape it correctly. I need to put the gas tank back in so I can drive it and see if it's better. Any advice would be greatly appreciated. I apologize for the long post. The rest of the gears engage fine, I think the shifter adjustment is ok. |
914bub |
Oct 11 2017, 11:35 PM
Tonight I pulled the inspection cover on the trans. Everything looks great in there. No play between the shaft and the part the roll pin is retaining so I buttoned that back up. I pulled the rear shift rod and replaced the two ball bushings and the rear rod support bushing. The balls were within about a half mm of the old ones so they were worn but not terribly chewed up or falling apart.The rear support bushing is actually a little sloppier than the one I removed. I greased everything. I need to get the rubber boot that covers the shift rod at the rear bushing.
I pettered out as today was long at work. I didn't get the gas tank in so no test drive tonight. I should be able to drive it tomorrow. How do I check the clutch cable tube? Engage the clutch while feeling in the tunnel for movement? If I can figure out how to check it I'll probably run out tonight and check it. i am currently not running a lock nut on the clutch cable. I looked for one when I did the clutch and couldn't find one but I'll put on an incorrect one for now so I have one. Thanks again for all the guidance and advice. Pix: |
Lo-Fi Version | Time is now: 14th May 2024 - 12:59 PM |
