May have found my transmission problem? |
914bub |
Oct 11 2017, 12:01 AM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
I have had a shifting problem since I got my 914 almost 4 years ago. When I got the car the clutch was toast so I replaced all the clutch related parts, including the flywheel. Once I got the car driving I realized it wouldn't go into first gear. I speculated that first gear had gone out and the previous owner had driven starting out in second, finishing off the clutch. The car had been parked since 1990 and the PO is deceased so it was just a guess.
The ball bushing at the base of the shifter was destroyed so I ordered a shifter bushing kit and replaced that bushing as well as,(if I remember correctly) the two ball bushings at the firewall.The car would grind and grind but wouldn't go into first gear. After reading a bunch of threads here I decided to pull the nose cone and replaced first gear and syncho with a marginally better set of parts out of a side-shifted core trans I have here. Success! So I thought........ First gear worked well for about a week and a half, then back to the same old game. I found it hard to believe I installed parts that literally had a couple weeks of life left in them. I pulled the pedal assembly out about a year ago and then got busy playing with motorcycles. I finally got it back together and in this week.( I rebuilt it not because I thought it would solve my first gear problem but it just needed it).After getting everything together I was looking at the linkage trying to see anything awry and I found this: I apologize for the washed out picture but you should be able to see what I'm talking about. The bushing the shift rod goes through has NO play although it is old. The shift rod slides freely through it as well. I loosened the bracket and pryed it so the shift rod was more centered in the linkage coming out of the transmission but it seems like it could go a little higher up and be a little "happier". Sorry I didn't take an after picture, I can tomorrow. My biggest question is should the end of the shift rod be as "hourglass" shaped as it is or is that all attributable to wear? I can drop the shift rod for a better picture, or if someone has a picture of a "good" one I can compare to? If it is worn our machinist at work can build it up if needed so I can shape it correctly. I need to put the gas tank back in so I can drive it and see if it's better. Any advice would be greatly appreciated. I apologize for the long post. The rest of the gears engage fine, I think the shifter adjustment is ok. |
914bub |
Oct 20 2017, 12:15 AM
I'm adding a final post,not because I think anyone is fascinated with the thread, but because I can't stand finding old threads and reading them, only to find they were never resolved. I didn't fix my first gear problem and I'm throwing in the towel.
I verified that the clutch tube isn't loose and double nutted and readjusted the clutch. I found an old 914world thread that said rocker arm shaft retaining nuts are the same as the clutch adjusting nuts. Thanks to Mr Mueller I had one of those. After all that I still couldn't get first gear so I adjusted the clutch even tighter. Too tight in fact as I wanted to see if it would go into first that way,.....nope. I still find it hard to believe that I installed a used first gear that only had a few minutes of life left in it but apparently that's the case. I really wanted to get this resolved. I was planning on the side shift conversion but I wanted to know if I had a good used tail shifted trans for a potential future 914. I also only have MOST of the conversion parts. One question I had about the conversion was shifter adjustment. I've read a lot about it and what I was wondering is where do you start at "ground zero" when doing the conversion? The threads I read said to mark your linkage with a sharpie before starting so you know where you started. Do I just assemble the shifter linkage with everything about 50% if that makes sense? In other words, assemble everything set about "in the middle" or the ramge of adjustment and go from there? |
Lo-Fi Version | Time is now: 12th May 2024 - 10:31 AM |
