May have found my transmission problem? |
ChrisFoley |
Oct 20 2017, 05:54 PM
I am Tangerine Racing Group: Members Posts: 7,907 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
After reading a bunch of threads here I decided to pull the nose cone and replaced first gear and syncho with a marginally better set of parts out of a side-shifted core trans I have here. Did you replace the slider? Yes, I did, however, it was used. If the slider isn't dead, I would suggest a new synchro brake band might take care of any grinding. If it won't stay in gear, you need a new 1st/reverse slider, new synchro ring on first gear, and probably a new brake band as well. Low mileage used (ie. VG condition) would also be acceptable. |
DM_2000 |
Oct 20 2017, 06:16 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
914bub |
Oct 20 2017, 11:37 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
Just to be thorough, ground strap in place? If not the cable becomes the ground and erodes/stretches until it breaks. However, your question about shifter adjustment makes me think that there may be your issue. Read my 31 pages of notes link below, it has a shifter and clutch adjustment section for how I do it. Racer Chris has another method that is different than mine, but is also tried and true. Check that stuff and get back to us. FYI, most tail shifters are really roached and not great for conversion. However, I have everything you need inside and out so you are not totally boned. Really just not optimal, but still workable. Ground strap is in place. I have read your notes but it has been a long while since I did. I haven't reread recently and will do so. I've also read Racer Chris' method on the shifter adjustment.I bought 2 sideshift trans from a friend who parted one out of his sons wrecked 73 and one he had out of his 75 that had issues. By issues I mean something was ground up inside but it wasn't first gear.The 75 trans is the one I pulled the first gear and related parts out of. I think all I need to complete my conversion parts list are the brackets and bolts that go at the ends of the engine mount bar. I'll dig my parts out and get a WTB ad placed. Thanks again for all the input. |
914bub |
Oct 21 2017, 12:46 AM
I ran out and took a picture of what I have for transmission conversion parts. I also have the transmission of course. Am I correct in thinking I am only missing the two kind of triangular brackets that go on the rubber mounts and the bolts that go up through the end of the engine mount bar as well as the upper "tabs" that go on the bolts?
Luke M |
Oct 21 2017, 07:58 AM
Senior Member Group: Members Posts: 1,368 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I ran out and took a picture of what I have for transmission conversion parts. I also have the transmission of course. Am I correct in thinking I am only missing the two kind of triangular brackets that go on the rubber mounts and the bolts that go up through the end of the engine mount bar as well as the upper "tabs" that go on the bolts? Looks like you need the steel U tabs/bolts/nuts/washers that replace the early rubber mounts, the late rubber mounts that mount on the late cross bar, the engine mount brackets, and all new conv bushings. You may want to reach out to Bruce Stone or Garold Shaffer for the missing parts. |
Lo-Fi Version | Time is now: 19th April 2024 - 05:13 AM |
