FS: Miscellaneous parts. |
Keith914 |
Oct 11 2017, 01:15 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
FS:
1) Two original Weber 40IDF carbs made in Bologna Italy, both need a cleaning and a full service kit and all the fasteners (screw bolts). One is complete with 28 mm chokes $100, and one is missing one inner venturie and the accelerator lever and has 24 mm chokes $75. Good parts to convert your Empy's to Webers. 2) Complete peddle cluster requiring new bushings $50. 3) Original voltage regulator $50. 4) Set of 30 mm chokes for 911 Weber 40's $45 5) Original two piece spark plug tool $15. 6) Free plus shipping cost: good condition later rain tray (no cracks or broken pieces, not in picture), fuel sender, window cranks, side shift mechanism, clutch fork, battery cut-off, heater lever, fuel tank rubber blocks and strap parts, headlight frames, two VDO 2 1/8" diameters fuel gauges one is new (GM spec), steering U joint, 911 tin pieces. |
tweet |
Oct 11 2017, 01:28 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
I will take the spark plug tool $15
and heater lever fuel tank strap parts (plastic bridge/clamp) Thanks, dan |
914_teener |
Oct 11 2017, 01:30 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I'll take the throw out fork but there is no price.
I'm in So Cal...as you know Keith. |
914_teener |
Oct 11 2017, 01:32 PM
Whoops.....okay free! I'll take it for shipping or see you at the Eiabachfest this Saturday?
Beach Run? Let me know. |
jmitro |
Oct 11 2017, 02:11 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
if the black headlight frames are good without cracks I will take them.
Sending PM |
gms |
Oct 11 2017, 02:40 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I will take the 2 - 911 engine sheet metal, VDO 2 1/8" diameters fuel gauges and shift mechanism
thanks |
Keith914 |
Oct 11 2017, 03:22 PM
Remaining items are: Carbs, Weber chokes, voltage regulator, gas tank rubber blocks, and steering UV.
koozy |
Oct 11 2017, 11:38 PM
Senior Member Group: Members Posts: 646 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I could use one of the fuel gauges if Glenn doesn't need both, and the steering u-joint please
Keith914 |
Oct 12 2017, 09:34 AM
Sea Dragon 914 |
Oct 12 2017, 11:13 AM
Member Group: Members Posts: 114 Joined: 26-February 03 Member No.: 358 Region Association: Northern California |
I could use the window cranks if still available. PM me cost and I'll send payment.
THanks, I could use one of the fuel gauges if Glenn doesn't need both, and the steering u-joint please Steering U-joint only item not already spoken for. Will get shipping cost. |
Wayne |
Oct 12 2017, 01:35 PM
SoCal-Bumblebee Group: Members Posts: 47 Joined: 29-January 16 From: Orange County, CA Member No.: 19,612 Region Association: Southern California |
I could use the fuel sending unit if still available
Let me know and Thanks Wayne 909-208-3184 |
bandjoey |
Oct 14 2017, 10:24 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
#2 for window cranks.
Keith914 |
Oct 15 2017, 08:42 AM
Lo-Fi Version | Time is now: 23rd April 2024 - 07:14 AM |
