FS: Miscellaneous parts. |
Keith914 |
Oct 11 2017, 01:15 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
FS:
1) Two original Weber 40IDF carbs made in Bologna Italy, both need a cleaning and a full service kit and all the fasteners (screw bolts). One is complete with 28 mm chokes $100, and one is missing one inner venturie and the accelerator lever and has 24 mm chokes $75. Good parts to convert your Empy's to Webers. 2) Complete peddle cluster requiring new bushings $50. 3) Original voltage regulator $50. 4) Set of 30 mm chokes for 911 Weber 40's $45 5) Original two piece spark plug tool $15. 6) Free plus shipping cost: good condition later rain tray (no cracks or broken pieces, not in picture), fuel sender, window cranks, side shift mechanism, clutch fork, battery cut-off, heater lever, fuel tank rubber blocks and strap parts, headlight frames, two VDO 2 1/8" diameters fuel gauges one is new (GM spec), steering U joint, 911 tin pieces. |
Lo-Fi Version | Time is now: 19th April 2024 - 08:23 AM |
