Front Oil cooler size for bigger six |
Justinp71 |
Oct 11 2017, 10:00 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
So I rebuilt my 3.0 into a much higher hp 3.2, I think its pushing 280hp. Problem now is just spirited street driving it runs at 210f with it be 80f outside; I'm sure on the track it will run 230+. I am running an engine cooler and the factory GT style Setrab oil cooler. If I want to run more track how large of an oil cooler do I need? What have you guys done in the past?
Also I am only running a GT lower valance, not a GT bumper, the hole seems large enough, could the GT bumper make that big a difference? Attached thumbnail(s) |
Oct 12 2017, 06:31 AM
I deleted the stock engine cooler and run a 20 row setrab cooler in the front with a fan pack. I was concerned about stop and go traffic so I feel the electric fan should help. It’s set to come on at 190. I also made sure the air exit was pretty generous. I have not ducted the cooler yet but right now I’m still sorting the car and have not put it through it paces in hot weather.
Justinp71 |
Oct 12 2017, 10:40 PM
I deleted the stock engine cooler and run a 20 row setrab cooler in the front with a fan pack. I was concerned about stop and go traffic so I feel the electric fan should help. It’s set to come on at 190. I also made sure the air exit was pretty generous. I have not ducted the cooler yet but right now I’m still sorting the car and have not put it through it paces in hot weather. Thanks. Is the fan pack on the cooler or on the floor? What size motor? When I had a stockish 3.0 it ran much cooler closer to 180-190 all the time except track was 230-240f. I also think my new larger headers are making more heat below the motor which is exasperating the problem. |
Oct 13 2017, 05:36 AM
I deleted the stock engine cooler and run a 20 row setrab cooler in the front with a fan pack. I was concerned about stop and go traffic so I feel the electric fan should help. It’s set to come on at 190. I also made sure the air exit was pretty generous. I have not ducted the cooler yet but right now I’m still sorting the car and have not put it through it paces in hot weather. Thanks. Is the fan pack on the cooler or on the floor? What size motor? When I had a stockish 3.0 it ran much cooler closer to 180-190 all the time except track was 230-240f. I also think my new larger headers are making more heat below the motor which is exasperating the problem. A built 3.2. Euro compression, 964 cams, custom chip, etc. running Ben's SS heat exchangers. Fan pack is on the cooler. Air exits the bottom of trunk from the stock holes in the cover plate - pried up covers that are held in place with seam sealer. |
ablesnead |
Oct 13 2017, 07:48 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
You need more air in , no fans to obstruct flow , sealed ducting , and ample unrestricted exit for warm air.....people ask this all the time , with the money and fabrication to get to this point it nuts to stop at the most critical system for long term track survival....if that doesn't give you the temps you need , then a bigger cooler....same install...15 grand and up for a good motor ...spend the 2 grand to cool the oil ...sheese !
Justinp71 |
Oct 13 2017, 10:12 PM
You need more air in , no fans to obstruct flow , sealed ducting , and ample unrestricted exit for warm air.....people ask this all the time , with the money and fabrication to get to this point it nuts to stop at the most critical system for long term track survival....if that doesn't give you the temps you need , then a bigger cooler....same install...15 grand and up for a good motor ...spend the 2 grand to cool the oil ...sheese ! Thanks, I will try that first. It's not a matter of spending money, I am more asking what size oil cooler I should have. But it sounds like making my airflow more ideal may be enough. Interesting, I never thought fans could actually hurt you on the track. Makes sense. Also to add to that- what is the ideal and acceptable oil temps for track? So far in my readings I gathered you want to stay under ~230f. |
ablesnead |
Oct 14 2017, 10:42 AM
I think 190...most like 220 ...some story about boiling off water from humidity....I think on a track car with appropiate changes that is akin to muffler bearing...My concern is keeping the heat expansion shifting too a minimum...I did the 12 hours with a 3 liter ..never above 190...but mild air temperatures...the higher temps come from the water cooled world in my opinion...
Oct 14 2017, 11:01 AM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I don't remember the exact make and model of the cooler i'm running, McMark would know.
No cooler on the engine and no fans. This keeps my 3.6L cool, runs at 180 all day on the street and gets up to 215 on the track. (IMG:style_emoticons/default/driving.gif) PS: The shroud is removable for easy access to the trunk. I can still store plenty of stuff in there actually. Just ignore the crappy louvers in the hood for now, eventually those will be made to look nice. (IMG:http://www.914world.com/bbs2/uploads/post-179-1177644949.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1177645001.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1177645013.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1363976080.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1374558362.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1374558258.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1374558273.jpg) |
ablesnead |
Oct 14 2017, 03:40 PM
I'm going to open a can of worms on this response to Andys photos of his hood vent . I am tired of dodging the intermittent rain here while trying to work on my sail boat , So what the heck , I may learn something . Several months ago , there was a thread that was discussing how to exit the warm air from your front mount cooler....Tons of ideas where mentioned but the first absolutely thing you would never do is duct it under the car....I think that may be completely false...an assumption like the need to adjust back pressure in tuning , or some such baloney....914 's generate lift...watch the rear in in a high speed turn....warm air creates lift in two ways , less density and higher velocity . Both would normally be desirable under a car ( lower pressure ) both would be undesirable over the car...again Lower pressure....ground effect devices that harness the air for a designed purpose are exempt from the above , if they exist
Oct 14 2017, 07:00 PM
I'm going to open a can of worms on this response to Andys photos of his hood vent . I am tired of dodging the intermittent rain here while trying to work on my sail boat , So what the heck , I may learn something . Several months ago , there was a thread that was discussing how to exit the warm air from your front mount cooler....Tons of ideas where mentioned but the first absolutely thing you would never do is duct it under the car....I think that may be completely false...an assumption like the need to adjust back pressure in tuning , or some such baloney....914 's generate lift...watch the rear in in a high speed turn....warm air creates lift in two ways , less density and higher velocity . Both would normally be desirable under a car ( lower pressure ) both would be undesirable over the car...again Lower pressure....ground effect devices that harness the air for a designed purpose are exempt from the above , if they exist I'll give you some real world experience to your theoretical engineering since i used to vent the hot air under the car for several years before i went with the shroud and hood vent. I can tell you in no uncertain terms that the car handles *much* better now at high speeds of 100+ mph. There's no if, but or maybe about it. Before, my car was scary at those speeds with the rear end being completely lose and all over the place. Now the car is firmly settled and the rear end is a lot more stable all the way up to my speed limit of about 135mph. I'm sure there'll be plenty of theoretical this and that about how that is caused by some or such not related to the venting, but all i changed was the routing of the hot air. Nothing else has changed on the car. (IMG:style_emoticons/default/driving.gif) |
wndsrfr |
Oct 14 2017, 07:24 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I moved from the Setrab to a Fluidyne DB30417....gives almost 50% more actual cooling surface area & is built like bulletproof....
ablesnead |
Oct 14 2017, 08:23 PM
Science is never valid for a true believer ....(IMG:style_emoticons/default/smile.gif)
Oct 14 2017, 08:57 PM
Science is never valid for a true believer ....(IMG:style_emoticons/default/smile.gif) I work in scientific research, you have not brought forward anything even remotely science related. (IMG:style_emoticons/default/shades.gif) |
Justinp71 |
Oct 14 2017, 11:33 PM
I moved from the Setrab to a Fluidyne DB30417....gives almost 50% more actual cooling surface area & is built like bulletproof.... Great thanks! Did you have the 12 row setrab designed to fit the stock gt oil cooler shroud? How much of a difference did it make? I like how it's aluminum. |
Justinp71 |
Oct 14 2017, 11:35 PM
Sir Andy, thanks for sharing your install detail also. (IMG:style_emoticons/default/smile.gif)
Krieger |
Oct 15 2017, 09:01 AM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
You need more air in , no fans to obstruct flow , sealed ducting , and ample unrestricted exit for warm air.....people ask this all the time , with the money and fabrication to get to this point it nuts to stop at the most critical system for long term track survival....if that doesn't give you the temps you need , then a bigger cooler....same install...15 grand and up for a good motor ...spend the 2 grand to cool the oil ...sheese ! (IMG:style_emoticons/default/agree.gif) |
ablesnead |
Oct 15 2017, 01:00 PM
Andy now you are being silly , air flow over and above a car is the primary interest in the science of fluid dynamics as it relates to race cars....directing warm air below a car is a common practice from F1 on down . to increase velocity to help both down force and reduce drag....a damn sight more than a vague claim that insignificant addition to the total airflow over your car made it go from not handling well at a 100 ....( that already shows a less than optimal setup ) to being an entirely different can at 135 . realize that the air stalls in front on your oil cooler to about 25 miles an hour at those speeds , it helps visualize just how small the volume of additional air is to the overall flow at 135. The under car volume is much less and even then its hard to quantify an improvement...thats why it basically doesnt matter with you car , sans other aero improvements....I know you blow all the above off , people have an emotional need to be right...but others that are using this site to improve there cars might have at least pause for thought .
Oct 15 2017, 01:28 PM
thats why it basically doesnt matter with you car I'm amazed how you can diagnose this from wherever you are without having ever driven my car. Neither before nor after the change to the air-flow on my cooler setup. Thanks for telling me what my car does or doesn't do, i had no idea! (IMG:style_emoticons/default/pray.gif) people have an emotional need to be right... I see you are no exception ... (IMG:style_emoticons/default/rolleyes.gif) |
ablesnead |
Oct 15 2017, 05:45 PM
You are welcome......apparently......touche
wndsrfr |
Oct 15 2017, 06:59 PM
I moved from the Setrab to a Fluidyne DB30417....gives almost 50% more actual cooling surface area & is built like bulletproof.... Great thanks! Did you have the 12 row setrab designed to fit the stock gt oil cooler shroud? How much of a difference did it make? I like how it's aluminum. Mine was a 19 row 6 inch high by 12 inch wide with 2 inch core. Earls number 81900ERL. Peter Dawe said to get a bigger one when he did my 2.7 "refresh". You can research the core sizes on line at the manufacturers websites to get the comparisons. Fluidyne looked the best to me. |
Lo-Fi Version | Time is now: 25th April 2024 - 10:12 PM |
