Front Oil cooler size for bigger six |
Justinp71 |
Oct 11 2017, 10:00 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
So I rebuilt my 3.0 into a much higher hp 3.2, I think its pushing 280hp. Problem now is just spirited street driving it runs at 210f with it be 80f outside; I'm sure on the track it will run 230+. I am running an engine cooler and the factory GT style Setrab oil cooler. If I want to run more track how large of an oil cooler do I need? What have you guys done in the past?
Also I am only running a GT lower valance, not a GT bumper, the hole seems large enough, could the GT bumper make that big a difference? Attached thumbnail(s) |
mepstein |
Oct 12 2017, 06:31 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I deleted the stock engine cooler and run a 20 row setrab cooler in the front with a fan pack. I was concerned about stop and go traffic so I feel the electric fan should help. It’s set to come on at 190. I also made sure the air exit was pretty generous. I have not ducted the cooler yet but right now I’m still sorting the car and have not put it through it paces in hot weather.
Justinp71 |
Oct 12 2017, 10:40 PM
I deleted the stock engine cooler and run a 20 row setrab cooler in the front with a fan pack. I was concerned about stop and go traffic so I feel the electric fan should help. It’s set to come on at 190. I also made sure the air exit was pretty generous. I have not ducted the cooler yet but right now I’m still sorting the car and have not put it through it paces in hot weather. Thanks. Is the fan pack on the cooler or on the floor? What size motor? When I had a stockish 3.0 it ran much cooler closer to 180-190 all the time except track was 230-240f. I also think my new larger headers are making more heat below the motor which is exasperating the problem. |
mepstein |
Oct 13 2017, 05:36 AM
I deleted the stock engine cooler and run a 20 row setrab cooler in the front with a fan pack. I was concerned about stop and go traffic so I feel the electric fan should help. It’s set to come on at 190. I also made sure the air exit was pretty generous. I have not ducted the cooler yet but right now I’m still sorting the car and have not put it through it paces in hot weather. Thanks. Is the fan pack on the cooler or on the floor? What size motor? When I had a stockish 3.0 it ran much cooler closer to 180-190 all the time except track was 230-240f. I also think my new larger headers are making more heat below the motor which is exasperating the problem. A built 3.2. Euro compression, 964 cams, custom chip, etc. running Ben's SS heat exchangers. Fan pack is on the cooler. Air exits the bottom of trunk from the stock holes in the cover plate - pried up covers that are held in place with seam sealer. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:03 PM |
