Front Oil cooler size for bigger six |
Justinp71 |
Oct 11 2017, 10:00 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
So I rebuilt my 3.0 into a much higher hp 3.2, I think its pushing 280hp. Problem now is just spirited street driving it runs at 210f with it be 80f outside; I'm sure on the track it will run 230+. I am running an engine cooler and the factory GT style Setrab oil cooler. If I want to run more track how large of an oil cooler do I need? What have you guys done in the past?
Also I am only running a GT lower valance, not a GT bumper, the hole seems large enough, could the GT bumper make that big a difference? Attached thumbnail(s) |
wndsrfr |
Oct 14 2017, 07:24 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
I moved from the Setrab to a Fluidyne DB30417....gives almost 50% more actual cooling surface area & is built like bulletproof....
Justinp71 |
Oct 14 2017, 11:33 PM
I moved from the Setrab to a Fluidyne DB30417....gives almost 50% more actual cooling surface area & is built like bulletproof.... Great thanks! Did you have the 12 row setrab designed to fit the stock gt oil cooler shroud? How much of a difference did it make? I like how it's aluminum. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:12 AM |
