Right head light blowing fuses |
JFG |
Oct 12 2017, 01:59 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I had a problem whereby the light bucket would not rise but would lower after manually winding it up. I used a check from pelican parts to jump between 87 & 30 in the relay socket (without the relay fitted)
This should jump the motor into a constant raise / lower mode in order to check the motor. It worked the motor perfectly. However when I now refit the relay it blows fuse 12 (16 amp) straight away. This never happened before and yes I removed the jumper wire first. Any help with this? |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:22 PM |
