Right head light blowing fuses |
JFG |
Oct 12 2017, 01:59 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I had a problem whereby the light bucket would not rise but would lower after manually winding it up. I used a check from pelican parts to jump between 87 & 30 in the relay socket (without the relay fitted)
This should jump the motor into a constant raise / lower mode in order to check the motor. It worked the motor perfectly. However when I now refit the relay it blows fuse 12 (16 amp) straight away. This never happened before and yes I removed the jumper wire first. Any help with this? |
jim_hoyland |
Oct 13 2017, 08:02 AM
Get that VIN ? Group: Members Posts: 9,270 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I just went through a similiar problem; turned out an external diode on the outer side of the HL Motor had broken and was shorting. Not easy to see at first; you have to poke around. Plus the diode is loosely covered by a black covering.
Some peeps have soldered the diode back; I replaced the Motor with one I got from Bruce Stone. See Andy thread with pictures of the problem: http://www.914world.com/bbs2/index.php?sho...=263805&hl= |
76-914 |
Oct 13 2017, 04:26 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I just went through a similiar problem; turned out an external diode on the outer side of the HL Motor had broken and was shorting. Not easy to see at first; you have to poke around. Plus the diode is loosely covered by a black covering. Some peeps have soldered the diode back; I replaced the Motor with one I got from Bruce Stone. See Andy thread with pictures of the problem: http://www.914world.com/bbs2/index.php?sho...=263805&hl= That's a damned good tip, Jim. Now if only I can remember that when and if the time comes. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:23 PM |
