Right head light blowing fuses |
JFG |
Oct 12 2017, 01:59 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I had a problem whereby the light bucket would not rise but would lower after manually winding it up. I used a check from pelican parts to jump between 87 & 30 in the relay socket (without the relay fitted)
This should jump the motor into a constant raise / lower mode in order to check the motor. It worked the motor perfectly. However when I now refit the relay it blows fuse 12 (16 amp) straight away. This never happened before and yes I removed the jumper wire first. Any help with this? |
JFG |
Oct 13 2017, 01:01 PM
Thanks for advice. After 3 more blown fuses I figured it was the relay. Strange though as it didn't blow before. Luckily I don't use all relays on the engine board so nabbed one off there and all things work as they should.
jim_hoyland |
Oct 13 2017, 03:50 PM
Get that VIN ? Group: Members Posts: 9,270 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Thanks for advice. After 3 more blown fuses I figured it was the relay. Strange though as it didn't blow before. Luckily I don't use all relays on the engine board so nabbed one off there and all things work as they should. Was it the relay in the front trunk ? Never had one of those go south.... (IMG:style_emoticons/default/sad.gif) |
JFG |
Oct 14 2017, 01:47 AM
Thanks for advice. After 3 more blown fuses I figured it was the relay. Strange though as it didn't blow before. Luckily I don't use all relays on the engine board so nabbed one off there and all things work as they should. Was it the relay in the front trunk ? Never had one of those go south.... (IMG:style_emoticons/default/sad.gif) Yes. I opened the faulty relay but to be honest i'm not sure what i'm looking at to diagnose a fault. |
Lo-Fi Version | Time is now: 3rd May 2024 - 10:09 AM |
