Right head light blowing fuses |
JFG |
Oct 12 2017, 01:59 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I had a problem whereby the light bucket would not rise but would lower after manually winding it up. I used a check from pelican parts to jump between 87 & 30 in the relay socket (without the relay fitted)
This should jump the motor into a constant raise / lower mode in order to check the motor. It worked the motor perfectly. However when I now refit the relay it blows fuse 12 (16 amp) straight away. This never happened before and yes I removed the jumper wire first. Any help with this? |
jim_hoyland |
Oct 14 2017, 05:03 AM
Get that VIN ? Group: Members Posts: 9,270 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I test them using a 9 volt battery and either an ohm meter (OM)
1st attach the battery to the 85 and 86 pins; you should hear a click indicating the opening of the circuit between 30 and 87 2nd, attach the OM to 30 and 87; there should be continuity until you disconnect the 30 or 87 You can do this with the relay cover off too.... |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:15 PM |
