what is wrong with the plaid installation?, is the plaid not in the right orientation? |
buck toenges |
Oct 12 2017, 03:37 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
Can you guys tell me if this plaid is correct in orientation and/or finished properly?
Attached image(s) |
Mikey914 |
Oct 12 2017, 04:39 PM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looks like correct material, at least from what I can see. The li rd are correctly lined up.
What are you seeing here that is questionable? |
Mikey914 |
Oct 12 2017, 04:45 PM
If you look at the factory color sample card the orientation is large strip down.
Attached image(s) |
buck toenges |
Oct 12 2017, 07:01 PM
the lady that owns the cart states that it was either stitched wrong or was installed wrong. She got the material from aa. Is it stitched across the seats wrong or is the orientation wrong? I don't know where she got the idea that it is wrong. That is why I thought I asked the experts here.
Buck |
buck toenges |
Oct 13 2017, 08:10 AM
What I found out is the lady thinks the material is on the wrong side. She thinks that it is turned inside out. She thinks the plaid is too bright and the other side is a more dull color. Are there 2 different colors? is there a correct side?
Thanks, Buck |
Mikey914 |
Oct 13 2017, 10:50 PM
I know our tartan has a backing so if it is installed "inside out" it would be a lighter color. The "backing helps to keep the weave from coming apart. I'm assuming that theirs is the same.
Should be easily solved by asking AA for a sample of their material. It will be obvious which side should be out. As far as the number of pleats something looks off. It looks like they did one fewer, but hard to really see from the pic. From an install point, the 1st pleat should have a little more "tuck" to it. |
Matty900 |
Oct 14 2017, 01:40 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
Here you go.
Attached thumbnail(s) |
worn |
Oct 14 2017, 10:04 AM
can't remember Group: Members Posts: 3,127 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Can you guys tell me if this plaid is correct in orientation and/or finished properly? One problem is that the weave is inherently made to look wrong to the eye. The horizontal stripes look fine as the heavy band is lowest and progresses nicely upward. But the vertical bands progress from one side to the other. We are made to feel that left to right pattern is wrong. The eye expects some sort of symmetry rather than a direction. Could be balanced by the other seat going in the opposite direct, but I don't think that is how they were originally done. After all the things were meant to catch your attention whether you like the patterns or not. Just like the green and yellow cars are faster. |
DM_2000 |
Oct 14 2017, 05:40 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
They've gone to plaid. . .
Attached image(s) |
Lo-Fi Version | Time is now: 28th March 2024 - 08:16 AM |
