rear caliper piston, not winding back on |
JFG |
Oct 15 2017, 09:08 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I started the refurb of my rear calipers today. i tested it before stripping and the hand brake piston worked as it should.
I watched the pmb youtube video and stripped the caliper but did not remove the handbrake mechanism. The easy side was refurbed first and all is good there. When i tried to reassemble the hand brake side i cannot get the piston to wind back on. I've tried lots of ways but no joy. So i checked the threads and both seem ok except for a small notch inside the piston itself (see pic) When i checked the threaded part inside the piston i can turn it quite freely, so trying to wind a bolt into it won't happen as there is no resistance. Any ideas? Is the mechanism inside the piston knackered? |
mobymutt |
Oct 15 2017, 05:19 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I'm sure others can give you a better answer, but since nobody else has chimed in yet...
I don't recall that interior bit being free to spin. I suggest taking the piston apart per the PMB video, cleaning it up, and putting it back together. Maybe if it was put together wrong, reassembling it correctly might solve the problem. |
cary |
Oct 16 2017, 07:50 AM
Ditto on watching the PMB video. I just watched the pertinent section for a refresh.
Counterclockwise. While pressing on the piston with the other hand. |
JFG |
Oct 16 2017, 12:02 PM
I've emailed pmb for bits as i think the thread is damaged and just won't allow the winding to start.
McMark |
Oct 17 2017, 07:00 AM
914 Freak! Group: Retired Admin Posts: 20,177 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
The entire assembly inside the piston is removable. At least on the early pistons the assembly pops out intact. I'm not 100% sure on the late style you have, but I am sure it comes out. I'm also sure that a competent machine shop would be able to fix those threads for you. Could be as simple as running a tap through them to clean up any deformations. The threads don't carry any load, so there's no real danger of 'weakening'.
Lo-Fi Version | Time is now: 28th March 2024 - 10:42 PM |
