rear caliper piston, not winding back on |
JFG |
Oct 15 2017, 09:08 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I started the refurb of my rear calipers today. i tested it before stripping and the hand brake piston worked as it should.
I watched the pmb youtube video and stripped the caliper but did not remove the handbrake mechanism. The easy side was refurbed first and all is good there. When i tried to reassemble the hand brake side i cannot get the piston to wind back on. I've tried lots of ways but no joy. So i checked the threads and both seem ok except for a small notch inside the piston itself (see pic) When i checked the threaded part inside the piston i can turn it quite freely, so trying to wind a bolt into it won't happen as there is no resistance. Any ideas? Is the mechanism inside the piston knackered? |
cary |
Oct 16 2017, 07:50 AM
Ditto on watching the PMB video. I just watched the pertinent section for a refresh.
Counterclockwise. While pressing on the piston with the other hand. |
Lo-Fi Version | Time is now: 15th May 2024 - 10:26 PM |
