What's the most likely cause of blinker NOT cancelling automatically, trouble-shooting a blinker that doesn't always cancel |
domer914 |
Oct 15 2017, 04:15 PM
Newbie Group: Members Posts: 41 Joined: 19-December 09 From: Oklahoma Member No.: 11,149 Region Association: None |
I am trying to solve for a blinker that works perfectly, except that it does not cancel automatically 100% of the time.
I am looking for a list of possible reasons that I can trouble-shoot. Replacing the stalks for hi/low beam and blinker and for wiper blades isn't crazy expensive, but before doing that I wanted to see if I could solve the problem myself. I'm grateful for any insights! Jim |
mzalanka |
Oct 15 2017, 05:42 PM
Member Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None |
You'll need to pull the steering wheel (but not turn signal assembly) to troubleshoot.
Probably one or more of three things, all interrelated. 1) after pulling the steering wheel, you should see a black plastic cancellation ring on the back of the steering wheel hub itself with about a 3/4" semicircular piece that hits the "cancel" tab on the turn assembly. This can get a groove worn in it over time. Or, it might be missing but probably not cause you'd never get a cancellation then. 2) the aforementioned "cancel" tab, part of the turn signal assembly, which is about a 1/8" piece of white plastic that extends when the turn signal is activated, could be worn or broken. 3) the turn signal switch could be gunked up with age. 1 & 2 can sometimes be fixed with superglue or plastic epoxy putty. 3 can be fixed, maybe, with cleaning. All three can be fixed with a new cancellation ring and turn signal assembly. Good luck! |
tmc914 |
Oct 15 2017, 08:07 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
You'll need to pull the steering wheel (but not turn signal assembly) to troubleshoot. Probably one or more of three things, all interrelated. 1) after pulling the steering wheel, you should see a black plastic cancellation ring on the back of the steering wheel hub itself with about a 3/4" semicircular piece that hits the "cancel" tab on the turn assembly. This can get a groove worn in it over time. Or, it might be missing but probably not cause you'd never get a cancellation then. 2) the aforementioned "cancel" tab, part of the turn signal assembly, which is about a 1/8" piece of white plastic that extends when the turn signal is activated, could be worn or broken. 3) the turn signal switch could be gunked up with age. 1 & 2 can sometimes be fixed with superglue or plastic epoxy putty. 3 can be fixed, maybe, with cleaning. All three can be fixed with a new cancellation ring and turn signal assembly. Good luck! Got my eye on this post because I am having a similar problem. Wasn't going to trouble shoot until next year but what the heck, maybe now I will have to if the answers are falling right into my lap. Gosh, if only I had a part number for that canceling ring which I suspect is missing after the PO fixed the horn. |
orthobiz |
Oct 15 2017, 08:36 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
One of my cars had the canceling ring installed upside down. Also, it can be reassembled too tight and not work. Has to have just the right amount of tension.
Paul |
SKL1 |
Oct 15 2017, 08:43 PM
Senior Member Group: Members Posts: 1,596 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I have to trouble shoot this on my '73- only cancels with right hand turns, never with left turns...
I might have screwed something when putting on the new Momo steering wheel. At least I don't have to deal with an airbag!! |
IronHillRestorations |
Oct 16 2017, 05:34 AM
I. I. R. C. Group: Members Posts: 6,707 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Most of the time it needs a new switch. There are nylon pieces inside that go bad
dcecc1968 |
Oct 16 2017, 05:55 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
As other have said, it may be as simple as rotating the cancellation ring.... solved my 2 year problem easy. If I remember correctly, there are 3 screws 120 degrees apart, try rotating the ring and reinstall. I think the protruding portion goes toward the passenger seat.
Oct 16 2017, 05:56 AM
Oct 16 2017, 06:17 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If anyone needs a new (used) steering wheel hub, I have a bunch. They are $10 and include shipping. You need to specify early ‘70-71 or late ‘72-76. Early has a metal cancel tab, late is plastic. PM or email - mark@markepstein.net
sithot |
Oct 16 2017, 09:33 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Jonathan Livesay |
Oct 16 2017, 10:20 AM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
That's a 914/6 part # there are several different ones for 4's, early are metal like the six but I think the attachment holes are located in different places. Late ones are plastic, and at least one year in the middle ('72 I think?) they had a wire that clipped onto the horn button instead of the spring loaded contact pin. And what Perry Kiehl said! |
Lo-Fi Version | Time is now: 29th March 2024 - 03:16 AM |
