Leaking trailing arms - both sides?!?, Shouldn't have touched the jack stands |
draganc |
Oct 15 2017, 04:32 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi guys,
I have completely rebuilt my brakes incl all hard and soft lines. I had the car on jack stands (what else) for the past 6 months and activated the brakes including parking every 1-2 weeks with firm pressure feel and no leaks whatsoever. Yesterday I took the car of the stands to turn it around and get it in position to install the engine again. Everything worked out just fine until I saw this spot underneath the rear right wheel: (IMG:style_emoticons/default/hissyfit.gif) Further quick investigation revealed "wet" spots in both trailing arms: Again, no leaks for the past 6 months until I put the car of the jack stands and pushed/rolled it around for 100ft. I was pressed for time and only had enough time to take off the rear right wheel to quickly glance at the caliper, which was professionally rebuilt and was dry on the outside. |
draganc |
Oct 16 2017, 03:09 PM
had a quick coffee wrenching break.
the calipers, pads and disk are bone DRY! i went through my parts stach and found two tubes of bearing grease, and i'm 99% sure that i have used the literally "no name" grease for the CV joints that it came with. squeezed out some samples, wait for it..............bang! the no name brand came out in a very clear "oil" and grease fashion, whereas the name brand is just simple grease. i guess that's the best proof that letting a old cars sit is not good. next stop taking the axle and cv joint out/apart. |
Lo-Fi Version | Time is now: 25th May 2024 - 06:02 AM |
