Leaking trailing arms - both sides?!?, Shouldn't have touched the jack stands |
draganc |
Oct 15 2017, 04:32 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi guys,
I have completely rebuilt my brakes incl all hard and soft lines. I had the car on jack stands (what else) for the past 6 months and activated the brakes including parking every 1-2 weeks with firm pressure feel and no leaks whatsoever. Yesterday I took the car of the stands to turn it around and get it in position to install the engine again. Everything worked out just fine until I saw this spot underneath the rear right wheel: (IMG:style_emoticons/default/hissyfit.gif) Further quick investigation revealed "wet" spots in both trailing arms: Again, no leaks for the past 6 months until I put the car of the jack stands and pushed/rolled it around for 100ft. I was pressed for time and only had enough time to take off the rear right wheel to quickly glance at the caliper, which was professionally rebuilt and was dry on the outside. |
porschetub |
Oct 17 2017, 08:18 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
This one had me thinking how brake fluid could even come out of the inside of the trailing arm ,I would try rotating the the axles to mix up the grease a bit,I'am running quality cv grease and no seals between axles and flanges "0" grease getting out.
Good luck. |
Lo-Fi Version | Time is now: 25th May 2024 - 03:39 PM |
