Engine Failure at speed... |
Cracker |
Oct 15 2017, 08:14 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Well, it is not "if an issue will occur on a race track" but rather just a matter of when! Sunday morning was gorgeous at roughly 65 degrees and cloud cover. The grip was surprisingly good and the dense, cool-ish air enabled the engine to run really strong.
The night before, a few of us "walked the track", taking in the nuances that really can only be seen on foot, kneeling down and taking our time. More drivers should take advantage of this to become more familiar with details that are completely missed behind the wheel of a car. Anywho... We were discussing an asphalt patch that is on entry into the downhill section to turn 10a...specifically, how the patch had an elevated center with ramps on either side. A friend mentioned, "hitting that at speed would cause quite the jolt to the car and driver". Also of concern was the potential loss of grip and the unsettling of the chassis at such a critical point. He was correct as I bore out witness the next morning. We have still not found the smoking gun and only hope it is not internal; the top-end is fully functional with each of the valves operation correctly. The engine does not turn over quickly and that obviously is a cause of rather great concern. I have been doing track events for some time now, over 15-years, and have never encountered such a failure. I guess I can say...enjoy the failure at my expense. PS: Talk about cutting it close...lose an engine down the hill; try to jump start the engine at turn 10a and just BARELY make it up the hill over T11 to glide back to the hot pits. Whew - that was close! (IMG:style_emoticons/default/biggrin.gif) Cheers! Tony https://www.youtube.com/watch?v=VRvMJeXJxTQ My son came in from college - great memories at the track with him! |
Cracker |
Oct 17 2017, 06:21 PM
Its all good...keep it coming. We noticed voltage and went to cables. You never know WHO would be reading this and gain some benefit! Thanks!
Tony |
DM_2000 |
Oct 18 2017, 04:34 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
Its all good...keep it coming. We noticed voltage and went to cables. You never know WHO would be reading this and gain some benefit! Thanks! Tony I don't know what gauge your cables are, but most consumer grade ones are more battery charging cables than true jumper cables. The consumer stuff is 10 to 6 gauge with thick insulation and poorly connected copper plated steel jaws. High end cables are a minimum of 4 G with 2 or 0 G being even better and have well terminated solid copper jaws. With real jumper cables, an engine should be able to be easily started without a battery in the car. If the cables can't do this, they are charging cables. With the car running, the battery voltage should be in the 13.8 - 14.2 V range, I looked at the vid and it looks like you are at 12 V ( difficult to see ) , this is too low. In any event, the battery voltage is too low, attempt charging then do a load test. |
Cracker |
Oct 18 2017, 04:46 PM
Busy work week! Normally the gauge reads right at 14v...I am not even pulling the car out the hauler until Saturday. My cables are CABLES...they were built specificatlly to be used on our 1100 hp/600ci mile car.
Tony Its all good...keep it coming. We noticed voltage and went to cables. You never know WHO would be reading this and gain some benefit! Thanks! Tony I don't know what gauge your cables are, but most consumer grade ones are more battery charging cables than true jumper cables. The consumer stuff is 10 to 6 gauge with thick insulation and poorly connected copper plated steel jaws. High end cables are a minimum of 4 G with 2 or 0 G being even better and have well terminated solid copper jaws. With real jumper cables, an engine should be able to be easily started without a battery in the car. If the cables can't do this, they are charging cables. With the car running, the battery voltage should be in the 13.8 - 14.2 V range, I looked at the vid and it looks like you are at 12 V ( difficult to see ) , this is too low. In any event, the battery voltage is too low, attempt charging then do a load test. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:38 AM |
