Prying open heat exchangers..., ... and crimping them closed again |
DaveO90s4 |
Oct 16 2017, 11:50 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Hi all,
It looks like the top section and the bottom section of OEM heat exchanges are simply crimped at the seams. Does anyone know if it is feasible to un-crimp them, take them apart and later on re-crimp them? If so, then I'll have a go at using the spare set of heat exchangers I have (with some modifications) for the heat exchangers on my to-be-built exhaust for my 2.8L Corvair transplant. Thanks all, Dave Oz |
malcolm2 |
Oct 17 2017, 08:09 PM
Govm'nt meddling again....
I wonder if you could get the fresh air fan to work well enough to pass the test. How do they check for that anyway? Why do you want to take them apart? are there holes? You could wrap it with that stuff "as seen on TV" They make a high temp version. Can't remember the damn name tho. You dip the roll in water and wrap whatever you want to wrap and it cures hard as a brick. I used some on my HE. 40000 miles and it is still wrapped enough to blow super hot air. Good Luck. |
DaveO90s4 |
Oct 17 2017, 10:07 PM
Govm'nt meddling again.... I wonder if you could get the fresh air fan to work well enough to pass the test. How do they check for that anyway? Why do you want to take them apart? are there holes? You could wrap it with that stuff "as seen on TV" They make a high temp version. Can't remember the damn name tho. You dip the roll in water and wrap whatever you want to wrap and it cures hard as a brick. I used some on my HE. 40000 miles and it is still wrapped enough to blow super hot air. Good Luck. I have to take them apart to be able to either: 1. Weld 3 inlet tubes from the three exhaust outlets into place on the existing tubing, or 2. As above and add complete new exhaust tubing if the current tubing is beyond further use. Don't think I can do either without 'peeling the banana'. Dave |
Lo-Fi Version | Time is now: 27th May 2024 - 06:38 PM |
