Is there a need for -6 oil lines? |
mb911 |
Oct 17 2017, 06:40 PM
914 Guru Group: Members Posts: 6,860 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have been able to locate the proper oil lines and fittings and believe I can also supply the hard line which many feel are to small but in actuality they are just fine as the inside of the oil tank is the same size as the id of the scavange line.
Anyhow I kind of looking for input as to if this is a valuable resource in such a way that I should invest in multiple sets to stock with oil tanks etc or are most people going the AN route? I am looking to make a complete oil supply system. I plan to also make a dipstick that reflects real qtys in my tanks.. Thoughts are welcome.. |
rgalla9146 |
Oct 19 2017, 11:25 AM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
One of the original hoses had a 90 degree fitting that attached through the hook on the 6 chassis.
Will yours have that feature ?.......Will the bottom hose be available without the adapter shown ? |
mb911 |
Oct 19 2017, 11:57 AM
One of the original hoses had a 90 degree fitting that attached through the hook on the 6 chassis. Will yours have that feature ?.......Will the bottom hose be available without the adapter shown ? Yes we have the 90 degree hose but the adapter hose is still incorporated.. I could eliminate it if there was that much demand.. |
Lo-Fi Version | Time is now: 28th May 2024 - 10:49 AM |
