123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount |
914_teener |
Oct 18 2017, 09:28 AM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
For those in the position of having a non-functional or failing distributor there is an alternative.
I ran into this issue while building a stock 2.0 motor for my car- while trying to source parts for what I thought was a functional stock distributor. The link is here for information: http://123ignitionusa.com. I talked to Ed ......he is based in Ohio and he said he would do group buy discounts if others were interested. Details: 914 models are available in the following configurations: 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. Coupon Code to use at checkout is: 914world Group Buy discount is 10% off retail on any product I offer. If there are more than 10 orders the discount becomes 15% and the additional 5% will be refunded to the cc of the first ten orders. This group buy is for shipping to any address Con US. The group buy will run for three weeks and orders will all ship 7-10 days after the close (Nov 10). Place all orders NOW using the coupon code, and that puts you 'on the list' but your part won't ship until mid-November. I.ll keep the thread bumped for a couple of weeks to measure or collect interest. Rob 10-22-2017 Edit: -Rob Here is the confirmed ...by me....orders that we have. Mark D. (McMark) was kind enough to edit some clarifications for the type of Dizzy to get. You are ultimately responsible...that way we all learn at least something. (IMG:style_emoticons/default/beerchug.gif) Here is the count I have: TJB/914 -1 914_teener-1 Philip W.-1 pvollma-1 Amphicar770-1 BeatNavy-1 nditiz1-1 CMONNETT-1 Bsherrard-1 olsib914-1 pete000-1 ( Met Pete at Luftenkult) I'll vouch for him. Morrie-1 I count 12 if for interest only, so if true that would be 15% discount off list. This will be great comparing notes on performance. |
JeffBowlsby |
Oct 19 2017, 02:01 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I thought if it had 'hardcoded advance curves" a vacuum can for advance/retard would be redundant and unnecessary. My stock '74 2.0L does not have a vacuum advance, only retard, but the 73 2.0L has an advance.
Does this 123 dizzy for stock D-jet provide the advance/retard functions to replace the vacuum can? |
mgphoto |
Oct 19 2017, 03:15 PM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I thought if it had 'hardcoded advance curves" a vacuum can for advance/retard would be redundant and unnecessary. My stock '74 2.0L does not have a vacuum advance, only retard, but the 73 2.0L has an advance. Does this 123 dizzy for stock D-jet provide the advance/retard functions to replace the vacuum can? Single vacuum port, if I have it correct the '74 D-Jet retard port only should connect to the dizzy vacuum port and switch set to B. '73 advance port connects to dizzy and switch set to #1. But I could be wrong. |
Lo-Fi Version | Time is now: 24th April 2024 - 06:13 AM |
