19 Pages V « < 15 16 17 18 > »
> 123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount
echocanyons
post Feb 3 2018, 04:36 PM
Post #305
I have the BT programmable version with L-Jet.
914_teener
post Feb 3 2018, 04:41 PM
Post #306
QUOTE(echocanyons @ Feb 3 2018, 02:36 PM) *
I'd check the cap to make sure it's on securely. Then the plugs gaps and the wires.
Just a quess.
echocanyons
post Feb 3 2018, 05:11 PM
Post #307
I swapped out a new coil, new wires and new plugs.
No chamge with any of these.
The strange thing is that it runs like a top initially then a few miles in it cuts out. It does this continuously once it starts and is basically undrivable after that. Once you let it sit for a while it works fine, then back to the same situation.
mgphoto
post Feb 3 2018, 06:29 PM
Post #308
"If there is a mistake it will find me"
QUOTE(Porschef @ Jan 4 2018, 06:47 PM) *
I'll have to check on that Kevin. I am running Ljet on a 2056 with a 9550 cam. I would like, no, really like to eliminate the pinging under hard acceleration at higher rpms.
This way, I could completely put my foot in it whenever... (IMG:style_emoticons/default/biggrin.gif)
I had the same issue, been dumping a bottle of MMT in a tank of regular gas, makes it act like 100 octane.
Found only 2 brands that work so far, Royal Purple and Lucas. Others don't seem to have the MMT concentration.
mgphoto
post Feb 3 2018, 06:33 PM
Post #309
QUOTE(echocanyons @ Feb 3 2018, 03:11 PM) *
Check your cap and rotor for cracks, small voltage marks along the sides of the terminals shorting to ground.
euro911
post Feb 3 2018, 07:33 PM
Post #310
I'd reinstall your original distributor and see if the problem is with your new distributor or something else.
Porschef
post Feb 4 2018, 11:59 AM
Post #311
How you doin'
QUOTE(mgphoto @ Feb 3 2018, 07:29 PM) *
Thanks for the tip, I'll give it a shot. (IMG:style_emoticons/default/beer.gif)
post Feb 4 2018, 12:13 PM
Post #312
Michael in Seattle
QUOTE(echocanyons @ Feb 3 2018, 01:55 PM) *
Is anyone having issues with this distributor?
I installed it and it was running beautifully for a short time.
Now it starts and runs fine at first but then has significant issues after driving for a few miles.
It seems like it is cutting out and not firing, this happens for a short time then it is ok for a while.
Prior to installing this there were no issues.
I really like the adjustable advance but it’s basically undrivable in its current condition.
Any ideas?
Have not seen this, but it's too rainy and cold to drive much where I am.
I'm curious whether there is any pattern to the temperature reading in the 123\Tune app when the problem occurs.
echocanyons
post Feb 4 2018, 01:35 PM
Post #313
I will give reinstalling the other distributor a shot.
I haven’t noticed a difference in the temp, I’ll have to do a test run and see.
I didn’t notice any voltage drops when this was happening on the app.
echocanyons
post Feb 4 2018, 03:03 PM
Post #314
What should the normal peak temp be for the distributor?
I just changed the wires and cap we will see if this helps.
914_teener
post Feb 5 2018, 12:23 AM
Post #315
QUOTE(echocanyons @ Feb 4 2018, 01:03 PM) *
Not sure what the normal op temperature of a stock distributor is. Good question.
There was some "loose" discussion of 90C as you might have read, might be a problem.
90C translates to 194F. I've had mine out in 100 plus temps ambient and no issues.
I have a friend with and infraometer so I'll check when I can get a hold of it. I seriously doubt that is a or THE problem.
I think it uses the Hall effect to fire the spark. Since you have L-jet it can't be an MPS magnetic field. Inductance with the coil being to close to the dizzy?
Just wild a** guesses. I agree with Mark. Put the old dizzy back in....if it runs perf then it's the dizzy.
Morrie
post Feb 5 2018, 02:37 PM
Post #316
QUOTE(echocanyons @ Feb 3 2018, 03:55 PM) *
Any ideas?
Make certain your timing is set correctly. If you are not totally sure that TDC mark visible is correct, get a bore scope or even a well placed mirror and look at the back side of the fan. A "0" should come up in the slot there for TDC on #1. Maybe you somehow have too much advance, or maybe not enough, and the engine is running too hot.
Another possibility is that there is a thermal problem with one of the components inside the distributor (defects are possible, sometimes not the fault of the manufacturer but rather the component supplier). If you have an IR thermometer, go ahead and run the car till it acts up and measure the temp at the base of the distributor near the clamp. I have seen distributors so hot they hardened and crystallized the rubber O ring. You don't want to be THAT guy.
If you have followed everyone's advice, and have a well tuned engine, plus followed the installation instructions to the letter, it may be time to exercise your right to warranty repair/replacement from 123.....
Does anyone disagree?
StratPlayer
post Feb 5 2018, 03:21 PM
Post #317
StratPlayer
No disagreement here, I've been running my 123 for over a year without any problems what so ever. I'm running a D-Jet 2056 and I love this dizzy. Sorry to hear about the problems some people are having. (IMG:style_emoticons/default/sad.gif)
rhodyguy
post Feb 5 2018, 03:44 PM
Post #318
What is the role of the vacuum line that runs down thru the engine tin?
post Feb 5 2018, 03:48 PM
Post #319
Michael in Seattle
QUOTE(rhodyguy @ Feb 5 2018, 01:44 PM) *
The car came with a mechanical vacuum gauge in the dash, so I was curious to hook it up.
post Feb 11 2018, 07:31 PM
Post #320
Michael in Seattle
I don't know, but today I guess my dizzy was somewhere below 140ºF while engine was up to operating temperature on a cold day. Oil temp was 175ºF and cylinder head #3 was somewhere under 350ºF. Haven't had any distributor problems yet, and motor running much better with new DRLA 45s. Wish I had heat exchangers though.
echocanyons
post Feb 18 2018, 06:22 PM
Post #321
I tried to reinstall the old dizzy but for some reason it doesn’t work, I tried a different one and got the same result. I’m not quite sure what to think about that.
In regards to heat, I had the temp up to 185 and it seemed to work fine.
I put about 50 miles on it between yesterday and today and it only started acting up on the last three miles.
I’m thinking that this may be a grounding or short issue rather than a primary issue with the dizzy.
1adam12
post Mar 2 2018, 10:54 AM
Post #322
Just out of curiosity, what is the need for the included spacer in these kits and did you have to use it for your application?
BeatNavy
post Mar 2 2018, 11:01 AM
Post #323
QUOTE(1adam12 @ Mar 2 2018, 11:54 AM) *
The shaft of the new dizzy is too long and otherwise won't fit snug on the case. So yes, you need the spacer to get it to fit properly in a type 4.
1adam12
post Mar 2 2018, 11:07 AM
Post #324
Thank you sir!
QUOTE(BeatNavy @ Mar 2 2018, 09:01 AM) *
- Lo-Fi Version Time is now: 20th December 2025 - 12:40 AM
