19 Pages V « < 16 17 18 19 >
> 123 Distributor Group Buy Thread, Replacement for NLA stock Dizzy's-Order 15 % Discount
rjames
post Jun 18 2019, 02:20 PM
Post #325
I'm made of metal
Reviving an old thread. Thinking about picking up one of these. Was going to start a new thread, but probably makes more sense to keep the info contained on a single thread.
My Q: How many people are running theirs with the stock coil? Given the entrance fee, I don't want to spend any more $ than necessary.
StratPlayer
post Jun 18 2019, 03:54 PM
Post #326
StratPlayer
When installing a 123 it’s recommended you buy a new blue coil
jim_hoyland
post Jun 18 2019, 03:58 PM
Post #327
Get that VIN ?
QUOTE(StratPlayer @ Jun 18 2019, 02:54 PM) *
(IMG:style_emoticons/default/agree.gif) Even if......
And, best distributer set up I've used; only mistake I made was not getting the Bluetooth version
914_teener
post Jun 18 2019, 05:58 PM
Post #328
QUOTE(rjames @ Jun 18 2019, 01:20 PM) *
You will be fine with the stock coil.
Morrie
post Jun 18 2019, 10:34 PM
Post #329
QUOTE(rjames @ Jun 18 2019, 03:20 PM) *
I am using the stock coil here also. Works great with my D-jet 2.0.
rjames
post Jun 18 2019, 10:49 PM
Post #330
I'm made of metal
Found the non Bluetooth version for a bit cheaper here (and only $10 to ship).
I’m running stock DJet. Is the Bluetooth version necessary?
123 Distributor
914_teener
post Jun 18 2019, 11:30 PM
Post #331
Read the first couple of posts in this thread for the right one to get.
BeatNavy
post Jun 19 2019, 05:30 AM
Post #332
QUOTE(rjames @ Jun 19 2019, 12:49 AM) *
123 Distributor
Yes, that looks like the correct part number for D-Jet models. Bluetooth is not necessary and in fact is not an option for D-Jet models (unfortunately). I think they didn't have the space to accommodate the trigger point functionality and requirements of Bluetooth.
The Ignition 1-2-3 USA sales rep has an account here. You can try PM'ing him if you have questions.
Rand
post Jun 19 2019, 03:38 PM
Post #333
Cross Member
QUOTE(914_teener @ Jun 18 2019, 09:30 PM) *
rjames, You do not need bluetooth. !
Installing mine soon, let me know if you want to collaborate.
euro911
post Jun 19 2019, 06:36 PM
Post #334
Mine is patiently hibernating until it's time to wake it up ... (IMG:style_emoticons/default/yellowsleep[1].gif)
rjames
post Jun 20 2019, 03:34 PM
Post #335
I'm made of metal
QUOTE(Rand @ Jun 19 2019, 02:38 PM) *
Purchasing the 123 distributor has been delayed for me. Just found out my MC is leaking. (IMG:style_emoticons/default/headbang.gif)
Keep me posted on how the install goes. I'll get there eventually....
rjames
post Jun 27 2019, 12:47 PM
Post #336
I'm made of metal
Ok, I bit the bullet and ordered the 123 distributor. Hopefully the install goes smoothly. Hope this will help in sorting out the current issues the car is having. The longer it doesn't run, the more I think about selling it when I eventually do get it running...
Ferg
post Sep 23 2019, 02:33 PM
Post #337
bumping an older thread to see if those who ordered and installed are happy and they have proven reliable?
It's on my winter list of possible upgrades.
TIA
Ferg
BeatNavy
post Sep 23 2019, 02:45 PM
Post #338
Yup, it's solid. I'm happy, and it's still rocking. Mine is the D-Jet one, and I'm using curve "B."
michael7810
post Sep 23 2019, 04:21 PM
Post #339
Mine has about 500 miles and not a problem. I have the Bluetooth unit and once I learned how it works the tune-ability is awesome. I tried a couple different curves including vacuum advance but I ended up with a straight line 0-28* at 3k rpm without vacuum advance. You really need a dyno to do anything more custom (or someone riding in the passenger seat to adjust the app while driving). I locked the distributor down at TDC so that my actual timing is equal to the distributor advance reading on the app.
You have to launch the app first, then turn the key on or it won’t connect (this is after the initial pairing).
rjames
post Sep 23 2019, 04:40 PM
Post #340
I'm made of metal
Simple install, plug and play. A few hundred miles on mine with no issues so far.
Ferg
post Sep 24 2019, 09:54 AM
Post #341
Cool, thanks everyone.
thomas@vintagecarleds.com
post Nov 25 2019, 02:26 PM
Post #342
QUOTE(BeatNavy @ Sep 23 2019, 03:45 PM) *
What are you setting your timing to at idle with curve B?
I am about to pickup on of these here soon!
DRPHIL914
post Nov 25 2019, 02:39 PM
Post #343
Dr. Phil
QUOTE(michael7810 @ Sep 23 2019, 05:21 PM) *
1,300 miles over the past 15 months since installing it. very happy. D-jet, running curve B I think with vac advance. in fact , drove it to work today, had not been driving it a lot partly due to recent failure and replacement of the master cylinder, also trying to keep it clean , don't want too much work to get it ready for the next car show here in 2 weeks.
you will like not having to mess with points and the f.i. trigger points plate!
BeatNavy
post Nov 25 2019, 03:28 PM
Post #344
QUOTE(DRPHIL914 @ Nov 25 2019, 03:39 PM) *
Pretty sure curve B is retard only, not advance. I've been running around 26 degrees on curve B on my new 2056 rebuild. Anything significantly higher than that and I was getting pre-ignition, presumably due to higher compression. Before the rebuild I was running it on a 2056 at 27 degrees without any issue, except it did want to idle slightly higher than factory.
It's solid.
- Lo-Fi Version Time is now: 20th December 2025 - 02:21 AM
