Steering Shaft, Feedback / Update |
jim_hoyland |
Oct 19 2017, 10:53 AM
Get that VIN ? Group: Members Posts: 9,256 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
When drive 10-15 mph on a local street that's not newly paved I get feedback up the steering shaft. It sounds like something is not tight. The steering wheel end has little play and the car has new shocks.
Any thought on where I should be looking ? 11/13/17 Update: turned out to be the top nut on the new Bilsteins was not tight, |
Steve |
Oct 19 2017, 01:04 PM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It’s a PIA... even if you remove the tank, there is a plastic cover that cannot be removed without dropping the rack. I cut mine off to replace the doughnut shaped bushing. My bushing was fine, but I replaced it anyway.
SirAndy |
Oct 19 2017, 01:20 PM
Resident German Group: Admin Posts: 41,602 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It’s a PIA... even if you remove the tank, there is a plastic cover that cannot be removed without dropping the rack. (IMG:style_emoticons/default/agree.gif) You can, however, drop the whole rack without removing the tank |
Lo-Fi Version | Time is now: 19th April 2024 - 07:41 PM |
