Cleaning Trannies?, These ones lived thru the barn fire |
pete-stevers |
Oct 22 2017, 01:39 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
I have a couple of transmissions that lived thru the barn fire
They are all black with soot ... I AM thinking oven cleaner... any other thoughts (IMG:style_emoticons/default/idea.gif) |
iankarr |
Oct 22 2017, 02:28 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Brake cleaner. Expect to go through 5-6 cans. Mineral spirits works great, but takes more effort. Are you planning on taking the gear stack out, breaking the box down and replacing the seals? If so, you can dip the cases or soda blast. I'd probably stay away from oven cleaner, as it may pit the box if you're not careful.
porschetub |
Oct 22 2017, 03:02 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Block off the case breather with duct tape,brush non caustic degreaser on and waterblast them.
A big NO to the oven cleaner as mentioned,how these clean up will most likely indicate how hot they got,@ minimum I would replace the input shaft and output shaft seals. |
Dr Evil |
Oct 22 2017, 08:22 PM
Oven cleaner is fine, I have run tests with it over months with no pitting. Old wives tail. Likely the best fit for your situation. You should pull the stack and wash the cases thoroughly. If I can help, let me know. What ever I have to give is yours.
914_teener |
Oct 22 2017, 08:38 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Block off the case breather with duct tape,brush non caustic degreaser on and waterblast them. A big NO to the oven cleaner as mentioned,how these clean up will most likely indicate how hot they got,@ minimum I would replace the input shaft and output shaft seals. If one water blasts it and doesn't pull the stack.....the gears will rust. Ask me how I know. |
Dr Evil |
Oct 22 2017, 08:47 PM
Block off the case breather with duct tape,brush non caustic degreaser on and waterblast them. A big NO to the oven cleaner as mentioned,how these clean up will most likely indicate how hot they got,@ minimum I would replace the input shaft and output shaft seals. If one water blasts it and doesn't pull the stack.....the gears will rust. Ask me how I know. Water will get in the side seals and other parts under pressure. Pressure wash is a bad idea unless disassembling. |
falcor75 |
Oct 23 2017, 04:59 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Ice pellet blastning should work, havnt tried it myself yet tho.
McMark |
Oct 23 2017, 06:11 AM
If not disassembling, slow, tedious, meticulous cleaning.
Pull the stack and diff, then soda blast. Then you only have to manually clean the intermediate plate. Plus you can inspect the internals in case something should be attended to now (perhaps something melted inside?). |
76-914 |
Oct 23 2017, 09:09 AM
Oven cleaner is fine, I have run tests with it over months with no pitting. Old wives tail. Likely the best fit for your situation. You should pull the stack and wash the cases thoroughly. If I can help, let me know. What ever I have to give is yours. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/shades.gif) |
Eric_Shea |
Oct 23 2017, 09:29 AM
Walnut
914_teener |
Oct 23 2017, 09:31 AM
.....and bake at 450 degrees until done (IMG:style_emoticons/default/smile.gif)
bretth |
Oct 23 2017, 10:53 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Wouldn't the whole case be warped depending on how close the cases were to the fire?
914_7T3 |
Oct 23 2017, 03:10 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Block off the case breather with duct tape,brush non caustic degreaser on and waterblast them. A big NO to the oven cleaner as mentioned,how these clean up will most likely indicate how hot they got,@ minimum I would replace the input shaft and output shaft seals. If one water blasts it and doesn't pull the stack.....the gears will rust. Ask me how I know. Water will get in the side seals and other parts under pressure. Pressure wash is a bad idea unless disassembling. Oooops, looks like I just screwed that up! (IMG:style_emoticons/default/sad.gif) Now going to add a rebuild to my resto to do list. Had a few small random issues with first gear and the down shift to second at times, so now whether or not to split open the transmission case has just been decided. |
whitetwinturbo |
Oct 23 2017, 07:30 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Test ZEP 505 on small sample.... (IMG:style_emoticons/default/smile.gif)
Mikey914 |
Oct 24 2017, 07:12 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Do look for crystallization of the aluminum. Of you see this you will probably not want to bother cleaning as the case will be shot. The internals should be fine.
No point in cleaning if it's garbage. |
Mikey914 |
Oct 24 2017, 07:14 AM
The only reason I mention this is I was with Rob and Chris yesterday and saw how hot the fires burned, aluminum will harden, but once the metal gets too hot it's done.
914_teener |
Oct 24 2017, 07:51 AM
Ah....the tranney case is magnesium.
iankarr |
Oct 24 2017, 09:00 AM
I have a spare case if anyone needs one.
Dr Evil |
Oct 24 2017, 06:07 PM
pete-stevers |
Oct 24 2017, 09:26 PM
Thanks Mike!
one of these trannys was rebuilt at a clinic the other was a good tranny from the 914 that burnt ... They both where out on a steel shelf a ways from the heat of the fire, there was a wooden table close by that was blackened but was not burnt.. So the order of business is just to take the black crap off of them... But I see pressure washing won't be a very good way... I dont really want to disassemble them... but we will see |
Lo-Fi Version | Time is now: 17th May 2024 - 05:13 PM |
